Which is More Acidic: Benzoic Acid or Formic Acid?
  • Thread starter Thread starter Cosmos
The discussion centers on the acidity comparison between benzoic acid and formic acid, with two conflicting arguments presented. The first argument claims that benzoic acid is more acidic due to the influence of the aromatic ring, which reduces electron density on the carboxylate carbon, enhancing its acidity compared to formic acid. The second argument suggests that the presence of two electronegative oxygen atoms in the carboxylate ion of benzoic acid pulls electron density away from the carboxylate carbon, making it less acidic than formic acid, which lacks such interactions. Despite these arguments, the consensus points to the Ka values indicating that formic acid is indeed more acidic, highlighting a disconnect between theoretical reasoning and empirical data. The discussion reflects a struggle to reconcile these differing viewpoints on acidity.
Cosmos
Well...hello brothers and sisters...may I know whether benzoic acid is more acidic or formic acid...because I have two arguments which support don't support each other...:frown::frown:
Chemistry news on Phys.org
Tell us what information you found.
argument 1: Due to the presence of the aromatic ring which pulls electrons slightly due to the presence sp2 hybridized carbon atom, decreases the electron density on the carboxylate carbon atom making it more acidic than formic acid which doesn't have such interaction.Thus, benzoic acid is more stronger than formic acid.
argument 2: Due to the presence of two oxygen atoms in carboxylate ion which pulls the electron from the aromatic ring slightly towards it as the oxygen atoms are more electronegative compared to sp2 hybridized carbon atoms. Thus increasing the electron density on the carboxylate carbon making benzoic acid less acidic compared to formic as there no such interaction in formic acid (negligible).
I have these two fighting arguments...:oldfrown::oldconfused:
Such arguments are quite handwavy, you are comparing apples and oranges.
Just check Ka values.
yes the ka values say that formic acid is more acidic but my reasonings are not able to fit...:oldcry:
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
