Which of the following double integrals would correctly solve this pro
  • Thread starter Thread starter ainster31
    Integrals
ainster31
Which of the following double integrals would correctly solve this problem?
I obtained two sets of boundary conditions.
Set 1:
$$x=-\sqrt{4-y^2}\quad (for\quad x<0)\quad to\quad x=\sqrt{4-y^2}\quad (for\quad x>0)\\y=-2\quad to\quad y=2$$
Set 2:
$$x=-2\quad to\quad x=2\\y=-\sqrt{4-x^2}\quad (for\quad y<0)\quad to\quad y=\sqrt{4-x^2}\quad (for\quad y>0)$$
This produces the following integrals:
$$\int_{-2}^{2}\int_{-\sqrt{4-y^2}}^{\sqrt{4-y^2}}(4-y)dxdy\\\int_{-2}^{2}\int_{-\sqrt{4-x^2}}^{\sqrt{4-x^2}}(4-y)dydx$$
So why aren't a, b, and c all correct? The correct answer is c. Why are a and b incorrect?
Looking at the diagram you want to choose the base correctly for symmetry of the sliced cylinder which is symmetrically split by the y-axis. So that means you would have to treat y as the independent variable and x as the dependent one so that gives you the x= sqrt(4-y^2).
That then implies the last choice C.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
