Which of these are vector and which are scalar?
  • Thread starter Thread starter singey
    Scalar Vector
Displacement, velocity, average velocity, acceleration, and position are classified as vector quantities because they provide both magnitude and direction. In contrast, distance and speed are scalar quantities, as they only convey magnitude without direction. The discussion emphasizes the importance of understanding the distinction between vectors and scalars in physics. Participants are encouraged to explore the concepts independently rather than seeking direct answers. This approach fosters a deeper comprehension of the subject matter.
singey
a) displacement
b) velocity
c) average velocity
d) distance
e) speed
f) acceleration
g) position
which of these are vector and which are scalar?
vectors give magnitude and direction. scalar only give magnitude
singey said:
a) displacement
b) velocity
c) average velocity
d) distance
e) speed
f) acceleration
g) position
How did you attempt to solve this problem on your own? You will be hard-pressed to find someone who will just give you the answer here.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
