Which proton would yield the most stable conjugate base?
  • Thread starter Thread starter MechRocket
    Proton
Protons A and B are considered more acidic than C, with A being the most acidic. The discussion revolves around the stability of the conjugate bases formed from de-protonation, with one participant arguing that de-protonation of C leads to a more stable conjugate base due to greater electron delocalization. Another contributor suggests that resonance structures for A and B should be analyzed to understand their stability better. The conversation also touches on the concepts of kinetic versus thermodynamic control, proposing that temperature may influence the acidity of the protons. Ultimately, the stability of the resulting enolate anions from each de-protonation site is a key factor in determining acidity.
MechRocket
[PLAIN]http://img638.imageshack.us/img638/5747/asdfnt.jpg
My workbook says that protons A & B are both more acidic than C, with the answer being A (I do get that A should be more acidic than B).
[PLAIN]http://img52.imageshack.us/img52/9800/asdfmi.jpg
I chose C though because de-protonation of C would access the more conjugated system. I would think there is more electron delocalization if you de-protonate C compared to A or B.
I posted this question on another forum and got the response that the reason is because the alpha hydrogens are closer to the Oxygen (electron-withdrawing), but I am not entirely convinced. In my undergrad Orgo course, I was told to always go with the proton that yields that more stable conjugate base, and I would think the base that results from de-protonation at C is clearly much more stable than the one that results from either A or B.
Is this a matter of kinetic control vs. thermo control or something? That's the only thing I can think of, where at low temperatures the proximity to the Oxygen makes A & B more acidic while at higher temperatures the yield would increasingly favor de-protonation of C. Just something I'm putting out there, but it's really just a shot in the dark.
Chemistry news on Phys.org
.. I would think the base that results from de-protonation at C is clearly much more stable than the one that results from either A or B.
I think you have come to that conclusion a little hastily. Have you tried to draw resonance structures for deprotonation at A or B? The key stabilizing feature of the resonance system you drew for deprotonation at C is that it includes a structure where the negative charge is localized on the oxygen in the anion.
All three deprotonation sites result in enolate anions ... you might want to look up keto-enol tautomerism to help understand this a little better.
I do think I have a good handle on keto-enol tautomerism. If you draw those resonance structures out (de-protonation of A & B), you will see that the conjugated system upon de-protonation of C is still much more extensive because the aldehyde is a Beta-unsaturated aldehyde.
I drew these side by side for you to compare (de-protonation of A #1 vs. de-protonation of C, #2):
[PLAIN]http://img692.imageshack.us/img692/1476/asdfhug.jpg
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
