Which wave reaches point B first?
  • Thread starter Thread starter ~christina~
    Point Wave
The discussion focuses on calculating which seismic wave, a P wave or a Rayleigh wave, reaches point B first after an earthquake at point A. The P wave travels through the Earth at a speed of 7.80 m/s, while the Rayleigh wave travels along the surface at 4.50 km/s. The distance between the two points, calculated using a specific formula, is approximately 6,670.64 km. Participants emphasize using the formula for speed (v = d/t) to determine the time taken for each wave to reach point B. The conversation highlights the importance of accurately calculating distance and time to solve the problem correctly.
~christina~
Two points A and B on the surface of the Earth are at the same longitude and 60 deg apart in latitude. Suppose an earthquake at point A creates a P wave that reaches B by traveling straight throught he body of the Earth at constant speed of 7.80m/s. The earthquake also creates a Rayleigh wave that travels along the surface of the Earth at 4.50km/s.
a) which of these 2 waves arives at B first?
b) What is the time difference in the arrival of these 2 waves at B? Take the Earth's radius to be 6,370km.
well I found this online for the distance
D= R arc cos[sin(lat 1) x sin(lat 2) + cos (lat 1) x cos (lat 2) x cos [ lon 2- lon 1]]
y(x,t)= f(x- vt)
well I first calculated the distance between the 2 points with the equation I found online.
R of earth= 6,370km
lat 1 = 0
lat 2= 60 deg => \pi / 3
lon 1= 0
lon 2= 0
D= 6,370km arc cos[sin(0) x sin(\pi / 3) + cos (0) x cos (\pi / 3) x cos [ 0]]
D= 6,370km arc cos [0 + 0.5]
D= 6,670.64km
x= 6,670.64km
But as to how to find the time has me confused a bit.
I think I use this equation where I just solve for time then subtract the 2 times for the different waves but I'm not 100% certain. (that's where I need help)
y(x,t)= f(x- vt)
for the 1st wave
y(6,670,640m,t)= f(6,670,640m - 7,800m/s (t))
same for the Raleigh wave
y(6,670,640m,t)= f(6,670,640m - 4,500km/s (t))
Or do I just use V= d/t and solve for t??
can someone help me out with which equation to use to find the time it takes for a wave to reach a certain distance?
Thanks
Well I'm not sure how to solve for t since isn't y the transverse position of the wave which I just don't have in the information?
Thanks a lot :smile:
Thanks
The same eqn as always, which you have written down.
A and B are two points on a circle of radius R. There are two paths to be considered here; one is a straight line from A to B, and the other is the arc from A to B. If you know the angle subtended at the centre, then the dist along the paths are known, and the time is got from dist/speed.
There is absolutely no reason for considering the wave eqn here.
It's interesting since I got the answer incorrect from what the book has. I think the distance is what is causing this.
You didn't say whether the way I got the distance is correct or not... Below
R of earth= 6,370km
lat 1 = 0
lon 1= 0
lon 2= 0
D= 6,670.64km
If the above way I got the distance from A=> B is incorrect then I'm not sure how I'd find it. I don't understand what you said about finding the distance.
Thanks
Since the two points are on the same longitude, simply think of the circle you'll get get if you slice it through that longitude. You now have to deal with just a 2-d circle, whose radius is that of the earth. The difference of the latitudes being 60 deg means that the radii from the two points subtend an angle of 60 deg at the centre.
Suppose the centre of the Earth is O. Angle AOB is given. Draw a simple diagram. Can you find segment AB? Can you find arc AB? Big calculations are not necessary, I think. :smile:
After you find the distances, use v=d/t.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
