Answer Work & Kinetic Energy for Mass m Whirling on Table
The discussion focuses on a physics problem involving a mass m whirling on a frictionless table, where the radius of its circular motion changes as the string is pulled. The key point is to demonstrate that the work done in pulling the string corresponds to the increase in the mass's kinetic energy. The solution involves applying Newton's second law in the radial direction and establishing that the quantity r²ω (angular momentum) remains constant. The work done is calculated through integration, leading to the conclusion that the work done equals the change in kinetic energy, confirming the relationship between work and energy in this scenario. The final affirmation of correctness indicates a successful understanding of the problem.
geoffrey159
Mass m whirls on a frictionless table, held to a circular motion by a string which passes through a hole in the table. The string is slowly pulled through the hole so that the radius of the circle changes from ##l_1## to ## l_2## Show that the work done in pulling the string equals the increase in kinetic energy of the mass
Work and energy
[/B]
I guess that the statement "the string is slowly pulled" means that the distance of the mass from the hole cannot change much in a short time, so I assume that ##\dot r = v_r = cst## and ##\ddot r = 0 ##.
By Newton second law in the radial direction:
## \vec T = m\ \vec a_r = m ( \ddot r - r {\dot \theta} ^2)\ \hat r= - mr {\dot \theta} ^2\hat r ##
There no tangential acceleration because there is no force in that direction so :
## 0 = a_\theta = r\ddot \theta + 2 \dot r \dot \theta = \frac{1}{r}\frac{d}{dt}(r^2\dot\theta) ##
So the quantity ## r^2\dot\theta ## is constant, and ##{\dot \theta} ^2 = \frac{c^2}{r^4}## where ##c ## is constant, and rope tension is now ##\vec T = -mc^2\frac{\hat r}{r^3}##
Since rope tension is a central force, its work from ##l_1## to ##l_2## is :
##W_{21} = \int_{l_1}^{l_2} T(r) dr = -mc^2 \int_{l_1}^{l_2} \frac{1}{r^3} dr = \frac{1}{2} m c^2 (\frac{1}{l_2^2} - \frac{1}{l_1^2})##
Because ## c = r^2\dot\theta = r v_\theta ##, and because ## \dot r = v_r ## is constant, then ##
\begin{align}
W_{21} =& \frac{1}{2} m ( v_\theta^2(l_2) - v_\theta^2(l_1)) \\
= & \frac{1}{2} m ( v_r^2(l_2) + v_\theta^2(l_2) - (v_r^2(l_1) +v_\theta^2(l_1))) \\
= & \frac{1}{2} m ( v^2(l_2) - v^2(l_1)) \\
=& \triangle K
\end{align}
Is that correct ?
YES! :)
