phys12345 said:
Variable speed of light is a hypothesis that states that the speed of light, usually denoted by c, may be a function of space and time. Einstein's first mentioned a variable speed of light in 1907, and he reconsidered the idea more thoroughly in 1911. As we know, Einstein developed his special theory of relativity, in which the constancy of light speed is a fundamental hypothesis. But I don't understand why he tried to set up the theory of variable speed of light. Does it not contradict the special theory of relativity?
The concept of "speed" has meaning only in the context of physically meaningful measures of space and time. The original theory of special relativity asserted that the speed of light in vacuum is c
when expressed in terms of a specific class of coordinate systems characterized by the homogeneity and isotropy of inertia. These are often called inertial coordinate systems. There was a tacit presumption that such a coordinate system could (in principle) be defined globally, covering all of space and time.
However, as Einstein tried to incorporate gravitation and the equivalence principle into this framework, he realized that this was not possible. The equivalence principle assures us that we can always define one of the special coordinate systems of special relativity (and Newtonian mechanics)
locally, i.e., within a sufficiently small region of space and time, and the speed of light will have the value c in terms of those coordinates in that infinitesimal region, but such a coordinate system cannot be extended over a finite region in the presence of gravity, due to what Einstein conceived as the "curvature" of spacetime. (There are other interpretations, but they are operationally equivalent.)
Consequently, any coordinate system that extends over a finite region (in a gravitational field) cannot have the properties everywhere that characterize an inertial coordinate system as defined above. In particular, the speed of light expressed in terms of an extended coordinate system in a gravitational field cannot equal c everywhere. (Note well that this does
not conflict with the fact stated above that the speed of light equals c everywhere in terms of a local inertial coordinate system.) In fact, the speed of light need not even have the same value in all directions at a given event. For example, the speed of light near a gravitating mass is non-isotropic when expressed in terms of Schwarzschild coordinates. (We can define coordinates in which it is isotropic, but it still varies in magnitude from place to place.)
Judging by some of the other comments in this thread, I think you may be confusing two very different subjects. When people talk (today) about possible variations in the speed of light (or the gravitational constant, etc.) due to cosmological evolution, changes in the properties of the vacuum, "deformed special relativity", or whatever, they are talking about local measures of the speed of light and putative secular or positional (or even random) deviations from the currently understood laws of physics. (Such variations would of course be manifested by changes in the dimensionless constants of physics.) This is totally unrelated to the variations in the numerical speed of light when expressed in terms of different coordinate systems, and the constraints placed by general relativity on the possible extended coordinate systems in a gravitational field, which is what Einstein was talking about in the 1907 and 1911 papers you mentioned. So, if your interest is in secular variations or vacuum fluctuations in the fundamental constants of physics, you're barking up the wrong tree by invoking the coordinate aspects due to the "curvature" of spacetime in general relativity. That's a completely different subject, and doesn't involve or imply any variations in the fundamental constants of nature.
phys12345 said:
If the light speed is assumed to be variable, then this assumption apparently contradicts the principle of relativity for Maxwell equations in free space, because from Maxwell equations, we directly know that the plane light wave propagates at a constant light speed, which holds in all inertial frames.
I took the liberty of bolding the phrase that answers your question. The point is that, in a gravitational field in general relativity there do not exist extended inertial frames. Such frames can still be defined in any sufficiently small region of space and time, and the laws of physics - including the speed of light - will be consistent with special relativity when expressed in terms of that inertial frame, but we cannot generally extend that frame due to the curvature of spacetime, as explained above.
pervect said:
So it doesn't make much sense to talk about a "variable speed of light". Occasionally people still try, but for the most part people are more careful and stick instead to talk about variations in unitless quantities, such as the fine structure constat.
See the FAQ here at PF for more information: https://www.physicsforums.com/showthread.php?t=511385
We can still talk meaningfully to some extent about measuring variations in the length of meter prototype bars, though it really simplifies things enormously to follow Duff's suggestion (see the FAQ) and talk about variations in the unitless fine structure constant instead.
I notice that Duff's paper was rejected by the journal Nature, and it contains appendices in which the negative comments of Paul Davies, two referees, and some others are discussed. One of the referees says "Duff has already published his views on this issue in: M. J. Duff, L. B. Okun and G. Veneziano, JHEP 0203, 023 (2002). It is to be noted that the other two authors of this article do not appear to agree with Duff that it is 'operationally meaningless' to vary dimensional constants." In his response, Duff doesn't seem to dispute that his co-authors of the published paper disagree with him. (He simply points out that this doesn't imply he is necessarily wrong.) Since Duff's (rejected) paper is cited as the main reference for the FAQ, I assume it was eventually published somewhere, although I couldn't find it.
Duff's main thesis (the basis for his disagreement with Davies) is that there is no operationally meaningful distinction between increasing e or decreasing c, because only the change in the dimensionless constant alpha = e^2/hc is operationally meaningful. But in response to one of his critics Duff gives this example: "In Einstein-Maxwell-Dirac theory, for example, one could imagine units in which (at least) five dimensional constants, are changing in time: G,e,m,c,h..., but only two dimensionless combinations are necessary: μ^2 = Gm^2/hc and alpha = e^2/hc". (I've omitted some subscripts for typographical clarity.) But this seems to undermine Duff's claims, because if he grants that these two dimensionless constants are operationally meaningful, it would seem that changing c would be distinguishable from changing e, because c affects both of the dimensionless constants whereas e affects only one of them. So doesn't this imply that (contrary to Duff) we actually
can distinguish between varying c and varying e? Of course, if we allow all five of the dimensional constants to vary, then any given changes in the two dimensionless constants could have a variety of explanations, but if we have it narrowed down to just changes in e and/or c, it looks like we could distinguish between them. Or am I missing something?
