votingmachine
- 306
- 84
If a thought experiment with hidden variables gave the same results as EPR experiments, would that be a publishable (even if minor) contribution?
votingmachine said:If a thought experiment with hidden variables gave the same results as EPR experiments, would that be a publishable (even if minor) contribution?
I was thinking of the common 3 detector experiment where the detectors results have 0.25 agreement when they are set at two different settings (AB, AC, BC) and 1.0 agreement when they are set at the same (AA, BB, CC).DrChinese said:It is generally accepted that there can be nonlocal hidden variables. So if your idea is along that lines... no one will really be interested.
If your idea is for local hidden variables, you will run into Bell's Theorem which says that is not possible. Bell supercedes EPR. I would not even consider putting forth such an idea until you thoroughly and expertly understand Bell. I can give you some links if that helps.
votingmachine said:I was considering whether I even should take that next step of reaching absolute certainty of the probabilities.
Strictly speaking, you mean "non-parallel" not orthogonal, right?DrChinese said:or orthogonal spins.
I think I see math errors in my spreadsheet. It was an old one and it was the reminder from several links that the odds should be 0.33 not 0.25 that reminded me of looking at it as a probability puzzle a long time ago. I had several odds generating sets and I can easily get higher than 0.33, but I think the lower bound is 0.33, on closer examination. I think that I have one set with split probabilities ... so that the odds are lower for some pairs but not the others. So for example, having p(AB) =0.25 is offset by p(BC)=0.41 ... still an average of 0.33.Nugatory said:Depends on how interesting you find the problem... You have an error somewhere, either in your calculations or in your understanding of what the exact challenge is. Finding the error could be a fair amount of fun, and educational too.
Nugatory said:Strictly speaking, you mean "non-parallel" not orthogonal, right?
votingmachine said:I was thinking of the common 3 detector experiment where the detectors results have 0.25 agreement when they are set at two different settings (AB, AC, BC) and 1.0 agreement when they are set at the same (AA, BB, CC).
I can think of a simple way to generate that result using ordinary objects. I am confident of those probabilities, although I don't think that is any solid basis to argue for or against hidden variables.
I would not mind reading further, although I have a good folder of papers, and I have the google.
I like this summary:
http://drchinese.com/David/Bell_Theorem_Easy_Math.htm
"if you randomly select any of the 3 pairs ([AB], [BC] or [AC]) enough times then you would expect to get matching results (++ or --) AT LEAST a third of the time. "
Obviously the QM results disagree. But if I had physical measurements of real objects (say mass, for example) that also gave a matching result 0.25 of the time, would that matter?
And I thoroughly agree that putting forth any idea without thorough understanding is a bad idea. I was considering whether I even should take that next step of reaching absolute certainty of the probabilities. I tend to think I'm more likely just looking at some detail that was long ago put to rest. But if the probabilities I give are correct is that just unimportant, or something that would need some further explanation?
EDIT: I apologize for not connecting your name to the link ... I really did not see your name. Your link is well written and I should have seen your name.
votingmachine said:I would have to say I am always puzzled by what would happen if you had 3 entangled particles and sent them to all 3 detectors. It would seem impossible for p(AB)=p(AC)=p(BC) to all still be 0.25. The requirement of the reduction of the result to 2 outcomes means that the DATA has to be in the form written in the table. If A is 1 and B is 0, then C must agree with A or B. It seems like a 3rd entangled particle leads to a problem with the probabilities. I think that is what I generated as a puzzle result.
Nugatory said:By "EPR experiments", do you mean the experiments that confirmed that quantum mechanics does violate the Bell inequalities?
A thought experiment with local realistic hidden variables that violates Bell's inequality would be a publishable and major contribution - but only if it can survive peer review, a necessary precondition for publishing anything.
The point of the peer review is to weed out the papers that are based on errors, faulty premises, or faulty logic. If a "thought experiment with hidden variables" matches the quantum mechanical prediction, the odds that it is not based on errors, faulty premises, or faulty logic are very close to zero (because this would imply an undiscovered flaw in the proof of Bell's Theorem) so the odds of such a paper actually making it through peer review are also very close to zero.
morrobay said:Rather that implying an undiscovered flaw in the proof of Bell's Theorem. Why not a more complete understanding of hidden variable physical mechanisms that could produce results that match quantum mechanical predictions ?
morrobay said:A local realistic or non realistic hidden variable theory that matches QM predictions.
bhobba said:As for a non realistic hidden variable theory Feynman's sum over histories formulation is technically just that. Its not realistic that objects take all paths at once.
Thanks, I think. Not easy math answers from anyone on these boards is a daunting prospect ...Nugatory said:You can google for "three-particle entanglement"; unfortunately the analysis of these states is appreciably harder and doesn't lend itself to the "...with easy math" approach that works so well with two particle states.
votingmachine said:I'll have to have a go at the 3rd entangled particle. I don't think it is necessary to rule out hidden variables, but it sounds interesting.
Just to nit-pick, unless my brain has lost a few more billion neurons in vital places, which is quite possible, that would go to zero at 90 degrees - correct for polarization, not correct for electron spins. And I think you are talking about such particles because you sayNugatory said:the quantum mechanical prediction about the probability of getting spin-up being equal to the square of the cosine
Electron spin follows the rule: the square of the cosine of half the angle. 90 degrees then gives you a probability of cos2(90/2) = (√2/2)2 = 1/2 which is what you want.Nugatory said:measurements on the same axis must always yield opposite results
Derek Potter said:Just to nit-pick, unless my brain has lost a few more billion neurons in vital places, which is quite possible, that would go to zero at 90 degrees - correct for polarization, not correct for electron spins. And I think you are talking about such particles because you say
Electron spin follows the rule: the square of the cosine of half the angle. 90 degrees then gives you a probability of cos2(90/2) = (√2/2)2 = 1/2 which is what you want.![]()
For each of the two cases, +,- and -, +.morrobay said:For opposite results : 1/2 cos2 θ/2
