Why are astronauts weightless?
  • Thread starter Forge
104
Disregard that last post my thinking was off. Was using my phone on top of a mountain doing tower work. Needless to say long day lol
1,506
Congratulations everyone....100 posts.
Isaac Newton would be impressed
79
643
27
Why are astronauts weightless.
Because the speed at which they are moving around the planet is balanced by the centerpetel effect.
For example there is a point where the astronauts speed is just right to maintain orbit without falling to Earth if too slow or speeding off into space if too fast.
When either of these undesired speeds are maintained then weight will be felt by the astronauts.
When the speed is balanced and just right they maintain orbit and no weight is felt.
If a ring of unobtanium was placed stationary around the earth a mile above it a person standing on that ring would feel and weigh much the same as someone stood on Earth. If you were to start rotateing the ring with the person on it his weight would get less and less as the ring rotated faster and faster untill there was no weight registered on the scale.
Doc Al
Mentor
44,815
1,078
Nope. No special speed is needed for the astronauts to be "weightless". All that is needed is for them to be in free fall.
643
27
Well what is free fall if it's not a special speed. If you were falling at a rate faster or slower than free fall would you not feel some kind of weight.
Doc Al
Mentor
44,815
1,078
Free fall is not a special speed. Free fall means that the only force acting is gravity.
95
Velocity in free-fall is determined by the force of gravity, as that is the only force on you.
Refer to the following formula.
[itex]V=\sqrt{\frac{GM}{r^{2}}}[/itex]
An object in free fall's velocity is determined solely by its distance from the object it's orbiting, and the mass of the body being orbited unless it is acted upon by an outside force, in which case it's no longer in free fall, which makes the whole thing a moot point.
A.T.
1,562
Forces determine acceleration, not velocity.
Free fall is more general than circular orbits.
643
27
If that is the case then is the second part of my reply true or false.
If it's true that a body falling at a faster or slower rate than the rate of acceleration due to gravity feels an effect caused by gravity acting upon it.Then we just disagree about what the meaning of special is with regards to free fall.
If it's false then I have to agree that free fall is not a special speed.
jbriggs444
7,807
2,747
The second part in question being, I think:
If you were in a uniform circular orbit and if your speed in this orbit were faster or slower than that which would make centripetal acceleration and gravitational acceleration match then there would have to be some other force, in addition to gravity, keeping you on this circular trajectory.
You would feel some kind of weight due to that other force. Not due to gravity.
If, on the other hand, you were moving horizontally near the earth, if the only force acting on you were gravity and if your speed were faster or slower than that which would put you in a circular orbit then you would still be in free fall. You would follow an elliptical, parabolic or hyperbolic trajectory.
But you would not feel any kind of weight.
Take this a step farther. If you are sitting at your desk, you are in a circular orbit around the earth at a rate of roughly one revolution per 24 hours. The force of gravity is pulling you down. Compressive and rigid forces in the earth's crust, mantle and core are holding you up. As others have pointed out, the weight you feel is due to the forces holding you up.
Doc Al
Mentor
44,815
1,078
You mean that if you are accelerating at at greater or lesser rate that the rate of acceleration due to gravity, do you feel some force acting upon you? Of course, since something other than gravity must be acting on you. (I see that jbriggs444 has addressed that.)
If you think there's something special about being in orbit that creates weightlessness, then you are wrong. Want to be weightless? Get shot out of a cannon! (Actually, that's not really weightless as there will be air resistance.)
As long as gravity is the only force acting, you will experience "weightlessness". Doesn't matter if you're in orbit or not. Consider the "vomit comet" used to train astronauts. That's never in orbit.
27
If you were shot out of a cannon you would feel weight as you accelerated out of it.
The same as if you were in a lift going upwards.Coming down is a different matter.
If you were born in orbit and maintained it you never experiance weight.
Being shot out of a cannon or going up and coming down in a lift you would.So there is something special about being in orbit you are unable to experience your own weight.
I'm pretty sure he meant after the initial acceleration. He also did note minus wind resistance.
95
That's true; however, the acceleration in the case of orbit is centripetal, and so velocity can be determined by the formula I posted above.
Agreed. I thought he was just talking about orbital freefall. If he's talking about free-fall in general, then disregard what I said; it doesn't apply in those scenarios.
643
27
Wind resistance noted.If he meant after the initial acceleration it would have been easier to say, throw oneself of a building which might sound a bit impolite.
Reagardless out of a cannon of a building or on board the vomit comet there is no difference than being in orbit apart from the amount of time you are weightless.
So it's not so so special.
Doc Al
Mentor
44,815
1,078
I had mentioned jumping off a cliff way back in post #55.
Good!
1,506
117 posts !!!! everything has been said over and over again. Nothing new is being discussed
1,506
ok, I'll continue to watch from the sidelines and keep count.
79
Actually I kind of like where this is going. We seem to be finding common ground and working from there to further our understanding.
1,506
I agree, I learn something every time I drop in here, long may it continue
Got to go now
643
27
As a matter of interest your speed might be faster or slower than that which put you in a circular orbit but would it remain constant if it followed an elliptical, parabolic or hyperbolic path.
jbriggs444
7,807
2,747
No.
Assuming that the only force that is present is gravity, then an object whose path takes it farther away from the Earth would slow down and an object whose path takes it closer to the Earth would speed up.
Doc Al
Mentor
44,815
1,078
No, the speed would not remain constant. It varies with the distance from the earth. As that distance increases, gravitational potential energy goes up and kinetic energy, and thus speed, goes down.
Related Threads for: Why are astronauts weightless?
  • Last Post
10K
