Why Are Branch Cuts Necessary in Complex Analysis?
The discussion revolves around the concept of branch cuts in complex analysis, particularly in relation to functions like ln(z) and the implications of defining multivalued functions in the complex plane.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants explore the definition and necessity of branch cuts, questioning the nature of |z|=1 and its relation to functions. There is discussion on how branch cuts help manage multivalued functions and the implications of choosing their locations.
Participants are actively engaging with the topic, clarifying definitions and assumptions. Some have provided insights into the nature of branch cuts and their role in complex analysis, while others are seeking further clarification on specific examples and definitions.
There appears to be some ambiguity regarding the definitions being used, particularly concerning the nature of |z|=1 and its classification as a function or constraint. Additionally, the discussion touches on the typical conventions for defining branch cuts in relation to the argument of complex numbers.
spacenerd
I was hoping someone could clarify the idea of a branch cut for me. In class, my professor talked about how a branch cut is used to remove discontinuities. He gave an example of |z|=1 needing a branch cut along the positive real axis. If this because going from 0 to 2\pi, the 0 and 2\pi match up?
|z|=1 is not a function
It seems like an implicitly defined function to me.
how do you figure?
|z|=1 seems to me like maybe an example of a path you would take in C, moving around the unit circle to show a given function is multivalued
Right, Well I guess I should have specified that z was an element of the Complex plane. Thoght it was kinda implied by the post title.
How about ln(z). I know that this is defined as;
ln(z)=ln|z|+i*arg(z), where 0<arg(z)<2pi.
This requires a branch cut to not include 0 and 2pi.
I'm just a little fuzzy on the notion of a branch cut.
it was clear z was an element of the complex plane, as per normal notation
what wasn't clear was which function you were working with. |z|=1 is not a function, it is a constraint, which represents the set of points on the unit circle in the complex plane.
when a function is multi-valued, you can choose where to put branch cuts in the complex plane so that no path that does not cross the branch cut is able to take you to a multivalued, ie for any path that crosses the same point z [itex]f(z) = f(z)[/itex] always
the location of a branch cut is not in general unique,you can chose where to upt it, however often it is specified by certain points
