Why Are Commercial Jet Windows So Small?
  • Thread starter Thread starter kevinnn
    Airplane Windows
Commercial jet windows are designed to be small primarily to withstand pressure differences, as smaller windows experience less force due to pressure changes. This design helps mitigate rapid decompression in case of a window breach, allowing pilots more time to descend to safer altitudes. Additionally, the structural integrity of the aircraft is enhanced by smaller windows, which reduces the risk of failure under stress. The discussion also draws parallels to construction principles, highlighting the importance of beam bending and load distribution in aircraft design. Overall, the size of jet windows is a critical safety and engineering consideration.
kevinnn
Why are the windows on a commercial jet so small?
I said because the smaller the window the less force that will be applied on it due to pressure differences. But since F=AP and the pressure stays the same the larger the windows are the more force they would be susceptible to. Is this the correct answer? Thanks.
There are more important considerations than that.
Yes I assumed there were. I believe another reason would be so that if a window was compromised the pressure would not drop in the airplane that fast because the air would have to escape out of a smaller area and the pilot would be able to get to lower altitudes in time. If the windows were large te pressure would change too quickly for the pilot to get to a safe altitude. Right?
Yes, that is a factor, too. I understand that such events have caused the loss of some planes in the past. But there is still a bigger issue. Have you ever seen a house being built?
Try thinking of it in terms of beam bending under a uniformly distributed load. The airplane is the analogous problem for a plate.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
