Why Are Some Materials Better Conductors/Insulators than Others?
  • Thread starter Thread starter mindboggling
    Conduction Rate
The conductivity of materials is primarily determined by their atomic structure and the presence of free electrons. Metals are excellent conductors due to their "sea" of free electrons that can move freely, allowing heat to transfer efficiently. In contrast, non-metals lack free electrons, relying on vibrating ions to transfer heat, making them poor conductors. The type of bonding—metallic, covalent, or ionic—also influences conductivity, with metallic bonds generally leading to higher conductivity compared to covalent and ionic compounds. Ultimately, the atomic arrangement and electron mobility are key factors in determining a material's conductive properties.
mindboggling
why are some materials better conductors/insulators than others?
it'll helped if explained at the atomic level
thanks
Is this a homework question? If so.. post some of your thoughts on the matter.
no, it's not a homework question. Just asking because i feel curious
after thinking about it for abit, i guess that the rate of conduction is related to the density of the object. So... a solid is a better conductor than a gas because the atoms in a solid are closer together. However is this true for metal ( a good conductor) and rubber ( a bad conductor)? Are my thoughts right?
You are right on your thoughts about a solid being a better conductor than a gas. Metals are better conductors that nonmetals, since they have free electrons which can move thoughout the substance. A metal structure is made up of positive ions fixed into place, with a "sea" of free electrons. If one end of a metal rod gets heated, then the ions at that end vibrate faster, and so an electron colliding with it gains kinetic energy, then moves to the colder end, and collides with an ion there, passing on the kinetic energy.
In non-metals, there are no free electrons, and the only way in which heat is passed down the material is by the ions vibrating, and pssing these vibrations onto their nearest neighbour.
ah so it really depends on the atomic structure of the material. If so, how does metallic, covalent and ionic compounds compare. Is one generally more conductive than the other, or it really depends?
Thankas cristo
I think it's easist first to watch a short vidio clip I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way? The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
