Why Are the Two Angles Labeled Theta Equal?
  • Thread starter Thread starter xatu
    Angles
The discussion centers on understanding why two angles labeled theta in a statics problem are equal. The first angle is formed between the position vector and the x-axis, while the second is between the moment and its y-component. It is clarified that both angles are complementary to the same angle, alpha, which leads to their equality. The relationship between the angles is reinforced by the fact that the moment vector is perpendicular to the plane formed by the force and the position vector. This geometric relationship ultimately explains the equality of the two angles labeled theta.
xatu
In my statics book (13th ed. Hibbeler) I'm reviewing the section about using vector analysis to calculate the moment of a force about a specific axis. I understand the theory fine, but I don't completely understand the figure in the book (pic attached). Specifically, why are the two angles labeled theta equal? The first tangle is between the position vector and the x axis, and the second angle is between the moment and it's y component.
Trig relations would obviously be of some help.
[/B]
Since ##r## is any vector from point O extending to the line of action of the applied force, doesn't that mean we can adjust ##r## and still maintain the same moment ##M_O##? Thus ##\theta## between ##r## and the x-axis is changing while ##\theta## between ##M_O## and ##M_y## remains the same?
What is Mo?
##M_O## is the moment of the force ##F## about the axis through point O.
OK. What is the direction of Mo in respect to the plane determined by F and r? What is the angle between Mo and r?
##M_O## is, by definition, perpendicular to the plane containing ##F## and ##r##. The angle between ##M_O## and ##r## is thus 90°.
Great. so now you see why the two angles are equal?
The angle between the y-axis and r should give 90 when added to theta, right?
Yes, but I don't exactly understand how the angle between the y-axis and ##r##, and the angle ##\theta## being complementary to one another tells us anything about the angle between ##M_O## and ##M_y##.
I get that the angles adjacent to ##\theta## are equivalent to ##90-\theta##, but, to me, that doesn't explain why both ##\theta##'s seem to be equal.
Can you please clarify?
If we call "alpha" the angle between r and My, it is complementary to both angles labeled "theta".
Or both angles have the same complementary angle (alpha).
Likes xatu
Thanks a ton, I got it now! Interesting way of looking at things!
