Why Are Two Coefficients of t in the t-Distribution Positive?
  • Thread starter Thread starter s3a
s3a
I'm attaching the question, answer, and my work. My work is almost 100% correct except that there are two coefficients of t that are supposed to be positive instead of negative and I marked those with red writing and would appreciate an explanation as to why this is the case.
Thanks in advance!
You have a sign error because you forgot to transform the equation in its (f(x,y,z)=0 form
that is, from the first formula you must substract z
that would give you the function F(x,y,z)=x²+2xy+5y²+x+3y+1-z
(notice that z changes sign which is what did not happen in your solution)
if you continue from there, you will get to a solution identical to the known answer (except maybe t will have a minus sign, but everywhere, so it doesn't change anything)
Cheers...
Thanks in advance!
For your tangent plane you have z = -13x - 43y - 112. You can also write this in standard form as 13x + 43y + z = -12. From this form, a normal vector can be obtained by inspection: <13, 43, 1>.
Thanks guys, I get it now! :)
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
