Why canal rays need a perforated cathode?
  • Graduate
  • Thread starter Thread starter ananthu
    Cathode Rays
3 replies · 12K views
ananthu
In the cathode ray production experiment, at about .01 mm of Hg, cathode rays travel from cathode and move towards anode and produce fluorescence on the walls near the anode.At the same time canal rays also move towards cathode. But only when you use a perforated cathode, the canal rays penetrate through it and produce fluorescence at the back of the cathode. I have doubts on the following aspects of the above experiment.
We are not using any perforated anode in the case of cathode ray production. Still these rays are able to produce fluorescence on the walls near the anode, thus indicating their presence. But why, the canal rays or the anode rays, so to speak, do need a perforated cathode to reach the other side and produce glow on the fluorescence screen kept at the back of the perforated cathode? Can not the anode rays make the walls near the cathode, glow even without a perforation in the cathode, as the cathode rays did?
As I am not able find the reason for it, it will be of great help to me if some experts on the subject throw some light on this aspect.
Canal rays are positive ions, while cathode rays are electrons or other negative ions.
None of them make it through if there are no holes ... the anode and the cathode are usually much too thick for particles to pass through; even a micron is too thick!
The fluorescence you see on the walls is from scattered electrons; they are much lighter than the positive ions, and hence scatter much more easily.
Thanks for the reply.Sorry for my delayed response.
Regarding the above statement, I could understand the light rays being scattered by an object. But how does it happen in the case of cathode rays? The latter being negative, when they hit the positive anode, will they not be attracted towards or absorbed by the anode rather than getting scattered?
Depends on the energy - if the particle energy is low enough there will be minimal scattering - but as the particle energy increases more and more scattering will be observed.
