Why Can't the Inverse Function Theorem Be Applied to a Function from R^n to R^m?
yifli
I know it is impossible to apply inverse function theorem on a function from R^n to R^m because the Jacobian is not a square matrix.
Is there any other reason why this is impossible?
Hi yifli! :smile:
If the inverse function theorem were applicable then we would obtain a homeomorphism between an open set of \mathbb{R}^n and an open set of \mathbb{R}^m[/tex]. But it&#039;s a result from topology that such an open set can not be homeomorphic.<br /> <br /> For example if n=1 and m=2, then there would exist a homeomorphism between an interval ]a,b[ and an open disk, but such an homeomorphism would never exist.<br /> <br /> Does this answer your question?
micromass said:
Hi yifli! :smile:
<br /> <br /> Yes. thank you so much!
micromass said:
Hi yifli! :smile:
If the inverse function theorem were applicable then we would obtain a homeomorphism between an open set of \mathbb{R}^n and an open set of \mathbb{R}^m. But it's a result from topology that such an open set can not be homeomorphic.
Actually I have another question regarding your answer:
A homeomorphism f is a bijective mapping which is continuous and has a continuous inverse. Inverse function theorem guarantees that f is continuous and so is its inverse, but what about bijectivity?
If it has an inverse, it is automatically bijective. In fact, this is an equivalence.
If you don't want to use the chain rule then try to show that the map can not be 1 to 1 from the higher dimensional space to the lower dimensional space.
