Why cant you dim a fluorescent bulb?
  • Thread starter Thread starter daniel_i_l
    Bulb
Fluorescent bulbs cannot be dimmed effectively due to their reliance on heated filaments and gas pressure for operation. The electronic circuits in fluorescent bulbs are designed for constant power supply, making them incompatible with standard dimmer circuits that cut power intermittently. When a dimmer is used, the filaments cool too much, disrupting the emission of electrons necessary for the bulb to function. Additionally, the electronic components of the bulb are not designed to handle the fluctuating power from a dimmer. Therefore, using a dimmer with fluorescent bulbs leads to inadequate performance and potential failure.
daniel_i_l
Why can't you dim a fluorescent bulb?
For a fluorescent tube to work, the filaments must stay hot enough to emit electrons and the gas hot enough to have a good pressure.
A fluorescent bulb is a fluorescent tube with an electronic circuit to feed and control the tube current.
A dimmer is an electronic circuit that control the how much time (in each half period) the charge is connected to the mains. It connects, say, two thirds of each half sinusoid to the charge.
This is incompatible with a tube without electronics, because the filaments will cool too much. This is also incompatible with the electronics of the bulb which has been conceived to be full time connected to the mains.
