Why do different formulae give me different answers for mass of galaxy?
Different formulas yield varying mass estimates for the galaxy due to discrepancies in the values used for the Sun's radial velocity and orbital period. The first calculation, based on centripetal force, gives a mass of approximately 1.7 x 10^41 kg, while the second method using Kepler's Third Law results in about 7.1 x 10^10 solar masses, equivalent to 1.4 x 10^41 kg. The third approach, also employing Kepler’s Law, estimates the mass at 1.3 x 10^41 kg. The variations arise from the different assumptions and parameters, particularly the radial velocity, which affects the calculations significantly. Understanding these differences is crucial for accurate coursework explanations.
anyaxo
I am trying to calculate the mass of the galaxy within the orbit of the sun.
M = Mass of the galaxy = ?
r = ‘Distance of sun from galactic centre = 7.6 kpc’ = 2.3 x 1017 km = 2.3 x 1020 m (2 sf)
G = Gravitational constant = 6.67 x 10-11 Nm2kg-2
v = ‘Radial velocity of the sun = 220,000 ms-2’
Since the Sun’s orbit around the galactic centre is nearly circular, it undergoes circular motion and experiences a centripetal force:
〖mv〗^2/r = - GMm/r^2
v^2 = GM/r
M= ((220,000)^2 (2.3 ×〖10〗^20))/(6.67 ×〖10〗^(-11) )
=1.7 × 〖10〗^41 kg (2 significant figures)
Using Newton's form of Kepler's Third Law..
r = ‘distance of sun from galactic centre = 1.6 x 109 AU (Astronomical Units)’ 13
T = ‘orbital period of the sun = 2.4 x 108 Julian Years’
M = Mass of galaxy = ?
M= r^3/T^2
M= 〖(1.6 × 〖10〗^9)〗^3/〖(2.4 ×〖10〗^8)〗^2
M=7.1 × 〖10〗^10 M_ʘ
This proves that if every star has approximately the mass of the sun, there are approximately 7.1 x 10^10 stars in the Milky Way.
7.1 x 10^10 Mʘ = 1.4 x 10^41 kg (2 significant figures)
Finally, by using the original form of Kepler’s Third Law we can also obtain the mass of a galaxy.
T = ‘orbital period of the sun = 2.4 x 108 Julian Years’ 15 = 7.57 x 1015 seconds
r = ‘distance of sun from galactic centre = 2.3 x 1017 km’ 13= 2.3 x 1020 m
T^2=(〖4π〗^2/GM)r^3
M= (4π^2 r^3)/(GT^2 )
M= (4 × π^2 ×〖(2.3 × 〖10〗^20)〗^3)/((6.67 × 〖10〗^(-11) ) 〖(7.57 × 〖10〗^15)〗^2 )
M = 1.3 x 10^41 kg (2 significant figures)
Why are my three answers (all in bold) so different? and which one is correct and why? I need to explain this for my coursework!
Using your values for R and T, I get v = 2πr/T = 1.91 x 10^5 m/s, which is not the same as the 220,000 m/s you use in the first calc.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
