Why do electric flux and charge have the same units?
Electric flux and electric charge share the same unit of coulombs, leading to questions about their relationship. Electric flux density is calculated using the equation D = εE, which serves practical purposes in electromagnetism. While electric flux is often expressed in terms of volts per meter (V/m), it is important to distinguish that this represents electric field intensity, not flux itself. The unit of electric charge is defined as ampere-seconds (A s), while electric flux is measured in volt-meters (V m). Understanding these distinctions is crucial for grasping the concepts of electric fields and charge interactions.
ankities
eletric flux and charge have same units ie coloumb
is it a coincidence or some similarity exists btw these two?
electric flux density D= εE is used for calculating flux ψ not E .why?(read tht it is done for practical reasons) please explain the practical reasons ,if any.
Electric flux is in V/m or Volt per distance, not coulomb.
no,V/m is electric field intensity not flux
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
