Why do F1 car have high horsepower rather than torque?
F1 cars prioritize high horsepower over torque because power, defined as the rate of doing work, is crucial for achieving speed. The analogy compares high torque to a bodybuilder, who is powerful but slow, while high horsepower resembles a sprint runner, who is fast but less powerful. In a scenario where both are on bicycles with different gear ratios, the cyclist with higher power will outperform the other, regardless of torque. Gearing can adjust torque and speed, but the overall power output remains constant. This discussion highlights the importance of power in racing performance, emphasizing that high horsepower is essential for speed in F1 cars.
AFS29
I've heard the analogy that a high torque car is like a bodybuilder, it is powerful but slow.
And a high horsepower car is like a sprint runner, it runs fast, but not as powerful.
Considering other factors constant.
if each tries to ride a bicycle to a certain speed,
and the runner is given a low gear ratio, while the bodybuilder is given a high gear ratio.
Wouldn't they both perform similarly?
Power is what matters. Power is the rate of doing work. The rider with the most power will win.
Power = Torque*rotational velocity
In SI units
Watts = Newton metres * radians/second (=joules/second)
Gears, or any other mechanical advantage, can exchange torque for rotational speed or vice versa but power remains constant.
A cyclist with adequate gearing could produce more torque than a Veyron, but the cyclist still only produces the same pitiful power output he always did.
This topic has been discussed here at PF more than once, a search will find more info.
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
19K
