Why Do Overloaded Brakes Emit Flames?
  • Thread starter Thread starter James889
    Friction
Overloaded brakes can emit flames due to the combustion of materials used in the braking system, particularly when they reach extreme temperatures. The fire results from a chemical reaction involving oxygen and combustible materials, which can include the brake pads or other components. While brakes may glow red hot, the visible flames indicate that some materials are burning off as they are subjected to excessive heat. The use of ablative materials in aircraft brakes may contribute to this phenomenon, as these materials are designed to dissipate heat effectively. Understanding the mechanics behind this can provide insights into brake performance and safety in aviation.
James889
Hello,
I saw this clip:
And i simply wonder what is the stuff that's burning?
Fire is a chemical reaction between oxygen, heat and some combustible material.
So shouldn't the brakes just be glowing red hot?
I'm no expert, but I would guess that the Airbus uses brakes that, when overloaded, shed heat using some kind of ablative materials and that it is this material you see burn away initially at least.
