Why do we assume that the circulating pi electrons induce B
  • Thread starter Thread starter FTNMR
    Electrons Pi
The discussion centers on the behavior of circulating pi electrons in aromatic compounds and their interaction with external magnetic fields. It questions whether these electrons induce a magnetic field that adds to or opposes the external field, particularly when the molecular structure is altered. The conversation highlights that the effect on protons depends on their position within the molecule, influencing their magnetic resonance in Nuclear Magnetic Resonance (NMR) studies. Specific examples, such as benzene and fullerenes, illustrate how the orientation of pi electrons can either deshield or shield protons, affecting their resonance frequencies. Overall, the relationship between molecular structure and magnetic fields is crucial for understanding chemical shifts in NMR.
FTNMR
Why do we assume that the circulating pi electrons induces another magnetic field, B_in, that adds to the external mag field, B_ext, instead of opposing B_ext? Couldnt the pi electrons just as easily oppose B_ext?
This lecture says the protons on benzene will experience greater effectual field, B_eff, because the circulating pi electrons induces another field that adds to the B_ext.
But if ring is flipped, then wouldn't that mean that B_in then opposes B_ext.. Also what if pi electrons circulate other direction? then according to RHR B_in would again oppose B_ext.
Im wondering if this has something to do with the fact that I am looking at this in 2 dimensions.. maybe not important idk..
Thanks for any explanation or help
Chemistry news on Phys.org
Well I'm thinking: an opposing field with be an extra negative field.
Do the pi electrons ever circulate to oppose the external field? i.e. if you flipped the ring, would the pi electrons start circulating the other way?
i.e. what makes them circulate?
is it the actual external mag field that causes the circulation to begin with? If it does then I think I am starting to understand, but if not then I think I am more confused. please answer again, thanks
OK i think it is the field that causes the pi electrons to circulate to begin with..so whether it opposes or adds to external field is just the right hand rule then.. is that correct understanding?
You "think"? You should go to your notes and check. I'm just asking you questions.
Just checking - it looks to me like a QM effect similar to Larmor precession.
Looking at something like ethyne - you can think of the atoms all lined up along the z-axis, but there is an ambiguity to how the triple bond electrons are oriented ... the time-average will be something like a cylinder. That should start you off ... or you can just use the result.
i.e. you are not "assuming" the result, it is the result because someone looked and discovered it.
Just like you don't assume that the Sun is a big ball of burning gas a long way away.
All the QM explanation will do is provide a math model for the result.
Whether the field increases or decreases depends on the position of the protons. There are some exotic aromatic compounds where one proton points inside the ring instead of outside and the field they feel is decreased instead of increased.
"Position of protons"? "... proton points..."?
Is this chemistry talk?
Guessing: location of atom in the molecule, and orientation direction of the nuclear magnetic moment?
It would be interesting to get some more information on the application. Is this perhaps an MRI (NMR) and the proton experiences a shift in the nuclear resonant frequency (at which r-f absorption takes place) from that of a bare proton because of local molecular magnetic fields(from the pi electrons) that add to the applied (static) magnetic field? It appears the subject might be chemical shifts in Nuclear Magnetic Resonance. A google of the topic shows quite a lot of studies have been done for the shifts found for various substances.
Well, 1H-NMR talk, to be precise.
Shameless self-advertisement (from my bygone days as a fullerene chemist): http://pubs.acs.org/doi/abs/10.1021/ja901383r
Whereas in benzene, the circulation of the pi electrons acts to deshield the protons, shifting their resonances downfield, in this case, the circulation of the pi electrons on the fullerene cage shields the methane protons (and the 13C nucleus) inside the fullerene, shifting their resonances upfield by a large amount (##\delta_H = -12.32## ppm and ##\delta_C = -20.62## ppm in case you don't have access to the paper). You see the same effect when H2, H2O, and NH3 are put into fullerenes.
Likes Charles Link
