Why do we specify chart image is open?
  • Thread starter Thread starter LAHLH
LAHLH
Hi,
When we define a manifold, and in particular define what a chart is, one of the conditions we specify is that the image \phi(U) is open in R^n. Why do we specify this?
For example if we didn't specify this and allowed closed balls, then we could cover S^1 by \theta where \theta \in [0,2\pi), and wouldn't need two charts.
I know that open balls and continuity go hand in hand, so I understand if we take U \subset M as an open interval and want to define a continuous map \phi then it must be that \phi(U) \subset R^n is open. But what if our U \subset M is not open, then why do we care if the image is open or not?
Basically why is this part of the definition?
I can't think of a good answer right now, so I'll just point out that f:X\rightarrow Y is said to be continuous if f^{-1}(V) is open for each open V\subset Y, and said to be open if f(U) is open for each open U\subset X.
Yep, sorry was being a bit sloppy above.
But then you wouldn't necessarily have the required continuity at \theta = 0
I think DrGreg's #4 works.
As an alternative way of looking at it, you want to be able to define a metric at a given point P in a chart. Say you want to express the metric as a line element d\ell^2=g_{ab}dx^a dx^b. You need to be able to fit those infinitesimally small dx's inside a neighborhood of P, without leaving the domain of your coordinate chart. If the chart is defined on an open set, then you're guaranteed that they fit. If it's not, then P could be a boundary point, and you would then have at least one dxa that didn't fit inside the chart.
Even if you're not interested in defining a metric -- say you just want to talk about manifolds as abstract topological spaces. The standard definition of a manifold is something that "looks like" (i.e., is homeomorphic to) \mathbb{R}^n locally. If you don't interpret "locally" to mean "on some sufficiently small *open* set," then you don't correctly capture the intended definition of a manifold, as opposed to a manifold with boundary or something else.
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
Thread 'Dirac's integral for the energy-momentum of the gravitational field'
See Dirac's brief treatment of the energy-momentum pseudo-tensor in the attached picture. Dirac is presumably integrating eq. (31.2) over the 4D "hypercylinder" defined by ##T_1 \le x^0 \le T_2## and ##\mathbf{|x|} \le R##, where ##R## is sufficiently large to include all the matter-energy fields in the system. Then \begin{align} 0 &= \int_V \left[ ({t_\mu}^\nu + T_\mu^\nu)\sqrt{-g}\, \right]_{,\nu} d^4 x = \int_{\partial V} ({t_\mu}^\nu + T_\mu^\nu)\sqrt{-g} \, dS_\nu \nonumber\\ &= \left(...
Abstract The gravitational-wave signal GW250114 was observed by the two LIGO detectors with a network matched-filter signal-to-noise ratio of 80. The signal was emitted by the coalescence of two black holes with near-equal masses ## m_1=33.6_{-0.8}^{+1.2} M_{⊙} ## and ## m_2=32.2_{-1. 3}^{+0.8} M_{⊙}##, and small spins ##\chi_{1,2}\leq 0.26 ## (90% credibility) and negligible eccentricity ##e⁢\leq 0.03.## Postmerger data excluding the peak region are consistent with the dominant quadrupolar...
