ELLE_AW
- 16
- 0
Why does Celsius degrees have +/- signs, since it's scalar?
The discussion revolves around the nature of temperature scales, specifically the Celsius scale, and the implications of using positive and negative signs in temperature readings. Participants explore the definitions and characteristics of scalar quantities, the significance of zero points in temperature scales, and the relationship between different temperature scales such as Celsius, Fahrenheit, and Kelvin.
Participants express multiple competing views regarding the nature of temperature scales, the concept of arbitrariness, and the implications of using positive and negative signs in temperature readings. The discussion remains unresolved, with differing opinions on the definitions and significance of the Celsius scale.
Participants reference the historical development of the Celsius scale and its relationship to other temperature scales, but there are unresolved questions about the implications of these definitions and the nature of scalar quantities.
How would you recommend temperatures below zero Celsius be indicated?ELLE_AW said:Why does Celsius degrees have +/- signs, since it's scalar?
Thank you so much for the distinction. That makes perfect sense.Dale said:Scalars can be negative. You are thinking of a magnitude which is strictly non-negative. Temperature is not a magnitude.
The celsius scale (also the Fahrenheit scale) uses values that relate to arbitrary points on an absolute temperature scale. That scale starts at Zero K so all temperature values are actually 'in the same direction'.ELLE_AW said:Why does Celsius degrees have +/- signs, since it's scalar?
sophiecentaur said:The celsius scale (also the Fahrenheit scale) uses values that relate to arbitrary points on an absolute temperature scale. That scale starts at Zero K so all temperature values are actually 'in the same direction'.
ELLE_AW said:Yea, the Kelvin scale makes more intuitive sense to me, but yea the arbitrary nature of that zero point makes sense too, as representing another temperature scale. Thank you!
boneh3ad said:The scale for Celsius was chosen so that 0 was the freezing point and 100 the boiling point of water
boneh3ad said:It's not really arbitrary, though. The scale for Celsius was chosen so that 0 was the freezing point and 100 the boiling point of water, two commonly-occurring phenomena in everyday life. ...
gmax137 said:Yes, but in the big picture it is arbitrary -- we could be doing our labs on the planet Zork, where atmospheric pressure is different.
Where I live, water boils at 204F. Oops, I mean 95.6 Celsius.
You mean 0° used to be the boiling point of water, and 100° was the freezing point? Well then I’m glad it got changed; that’s just confusing.Vanadium 50 said:Originally, the reverse. It was changed by Linnaeus (yes, that Linnaeus) after Celsius' death.
If the Celsius scale is "arbitrary", then so is the Kelvin scale. The difference of 1K is still based on boiling and freezing of water.boneh3ad said:It's not really arbitrary, though. The scale for Celsius was chosen so that 0 was the freezing point and 100 the boiling point of water, two commonly-occurring phenomena in everyday life.
Jeff Root said:It has a specific and logical reason, but it is arbitrary.
Lots of other values could have been used for equally
specific and logical reasons.
-- Jeff, in Minneapolis
Except for arbitrary definitions of "arbitrary".boneh3ad said:So... not arbitrary.
