Why does connecting a bjt backwards work?
  • Thread starter Thread starter rytmenpinne
    Bjt Work
Connecting a bipolar junction transistor (BJT) backwards can still allow it to function, as the symmetrical nature of its three-layer structure may lead to some operational similarities. However, this reversed configuration results in significant differences in performance, including reduced gain, increased electrical noise, and higher leakage current. The collector and emitter are not identical; they have different doping levels and physical structures that affect their behavior. While it may work in basic experiments, the transistor will not meet its specified parameters unless connected correctly. Understanding these nuances is crucial for effective transistor applications.
rytmenpinne
I'm trying to understand transistors so I bought a couple and have been doing some reading, I basicly got it but some quick experiments have me dumbfounded..
I have the most basic NPN transistor circuit setup http://amasci.com/amateur/transis2.html like thatone, only with a loudspeaker instead.. Now, why does it still work as expected if I simply flip/reverse the transistor so the collector connects to the '-'poles on the batteries?
This is actually the behaviour I've expected since NPN is symetrical, But I've understood that there is in fact a difference between the collector and the emitter. Enlighten me!
You are right that most bipolar junction transistors will "work" when the emiitter and collector are swapped over. As you said, conceptually the 3-layered structure "looks the same" from either side, even though the physical structure does not have symmetrical geometry, and the level of doping (deliberate impurities) in the two N regions is different.
The transistor will only match the parameters in its data sheet if it is connected the right way round. Otherwise, you will probably get lower gain (beta), higher electrical noise and leakage current, lower power dissipation limit, etc.
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
