Well what specific technology kind of motor is it?
Different motor types (e.g. single phase AC, three
phase AC, DC, capacitor start, shaded pole, et. al.)
have different failure modes and concerns associated
with them.
For capacitor start motors, for instance, it's quite common
to have capacitors that are either improperly installed or
which are somewhat degraded and need replacing.
Since the capacitor specifically controls issues of starting
and initial rotational orientation it could be an item
to consider in the face of such problems as yours.
You mention that your motor is rated for twice the
load weight that you're using, which is a good thing.
I will just mention, though, that the torque available
when starting is different than the torque available
when running at speed, so it's possible to have a motor
which has ample torque when running but not so when
starting. Since you say this motor and hoist mechanism
is commonly used together for that purpose, and is rated
for loads twice as high as your application, I'll assume
that all aspects of the motor capabilities are suited to
your usage (starting/running torque, duty, temperature,
lifetime, et. al.).
It is a common situation with motors to have one or
more windings which may simply be defective due to
broken connections or melted wire or short circuits due
to winding insulation defects.
It's certainly common for an old or abused motor to
develop such troubles, but it's also possible for relatively
new motors to unfortunately have such problems.
Depending on your particular motor's technology
it might be very reasonably expected that symptoms
of a partially or fully failed phase winding would be
exactly the problems that you are experiencing --
inconsistent starting, inconsistent running direction,
lack of available torque/power, et. al.
Other things to verify would be:
* Are you running the motor at its intended
power frequency?
* Are you attaching the motor to the AC power lines and
to its direction control etc. with proper connections
so that there are no missing phases, reversed wires,
broken wires, connections made to terminals that are
incorrect for the power voltage/phase that you're using,
et. al.? Certainly a 240VAC motor winding attached to
a 120VAC circuit, or motors with some reversed phase
connections, et. al. might exhibit problems like you see.
* Is the brake working properly, and when it is supposed
to be disengaged, is the motor permitted to turn freely
in either direction without friction?
* Is the coupling / belt / pulley on the motor shaft
working smoothly and not causing undue friction or
misalignment when operating in any direction with any
attached load?
* Do you smell burning / melting type scents near the
motor when it has been operating for a few operations
over a few minutes?
* Is your input voltage and current / power capacity
within specification? Sometimes having other equipments
drawing much power or connecting through too many
lossy connections / cables can rob the motor of needed
power, and some places just have unreasonably low
power capacities due to utility undercapacity.
* Is the motor properly lubricated?
* Is the hoist connected with the proper arrangements
of cables / pulleys / attachment points? Certainly
accidentally switching pulley tracks or cable attachment
points or some other such mechanical error could result
in improper mechanical gearing of the motor to the load
and thus exceeding the motor's capacity.
I suspect that you'll find that there is either a mechanical
or electrical fault that's been causing your problem;
inspect everything closely, double and triple check even
if your first glance and intuition is that everything is
correct.
And, of course, be safe; having a hoist that's liable
to unexpectedly drop its load or motor that may
run amok isn't a very safe situation, so keep well clear
of potential dangers due to unexpected failures / motions
until you're certain that the safety / operational
problems have all been identified and resolved!
ashokeez said:
Thanx XEZ for the reply.
Generally hoists/cranes don't have counterweight measures. Also in my case there is a space constraint where i can't employ counterweights. Again the motor is rated 2 times higher than the required capacity. Its a one ton hoist, but suspended load is only 500 kgs (0.5 ton). This was done not to overload the motor and for long life. As you told rightly, i used a high rated motor, so that no problems encountered. Roughly the motor uses only 50% of its capacity. And the hoist is standard one bought in market and used for various applications acros various fields. Therefore I cannot modify/redesign any parts and the hoist is proven in other similar areas. The point to be noted is most time motor functions in desired direction & very well lifts the suspended load. Sometimes it does not & rotates in opposite direction.
Now the issue is, when it's able to run in desired direction, is there any possibility to enforce the motor externally by some method to run in desired condition? Or whenever the motor lifts, can we simulate the same condition, all the time?? so that the motor will not assume its own direction & rotates in forced direction, either ccw or cw?
Any suggestion?? please!
