Why does the J-58 engine inlet spike retract at high speeds on the SR-71?
  • Thread starter Thread starter rbogie
    Engine Inlet
The J-58 engine inlet spike on the SR-71 retracts at high speeds to optimize airflow and maintain shockwave management. Initially extended to accommodate lower speeds, the spike's position is crucial for ensuring that shockwaves do not interfere with the engine's intake. At Mach 3.2, the retracted spike allows the shockwave to remain attached at the nacelle's front lip, facilitating subsonic airflow into the engine. The spike's adjustments also influence the distribution of air between the turbine and afterburner, with a significant bypass at maximum speeds. Understanding these dynamics is essential for comprehending the SR-71's high-speed performance and engine efficiency.
rbogie
I've been reading about the SR-71 and the J58 engine and I'm confused about what I've read about the inlet spike. The spike would start out extended 3 feet but as speed (Mach) went up it would retract, up to 26 inches when at Mach3.2. This confuses me as I thought you'd always want the shockwave to be at the lip of the engine inlet.
As Mach goes up the shockwave angle increases so that in order to have the shockwave at the lip of the inlet, I'd think you would have to Extend the spike, not retract it.
Maybe the lip of the inlet on the aircraft is still some distance away from the compressor face, Maybe its okay to have the initial shockwave in that inlet, because it will have reflection between the inlet wall and the back side of the spike. So many reflections that the shockwave will have 2 or more decelerations before the air becomes subsonic--at the compressor face.
Anybody know about this or know where I can see Schlieren photos of this interaction?
Some info
http://www.wvi.com/~sr71webmaster/j-58~1.htm
SR-71 Flight Manual » Section I (Description and Operation including Engine)
http://www.sr-71.org/blackbird/manual/1/ (see page 33)
SR-71 Flight Manual
Somewhere I found what you're looking for, but I can't seem to find it at the moment.
It might be available in some archives at Dryden. I'll keep looking.
Update: I found some notes showing shock patterns. Now I just have to track down the source, which I think was Lockheed. The article was "Case Studies in Engineering: the SR-71 Blackbird"
This site used the same source: http://www.456fis.org/YF-12A_SR-71_ENGINE.htm
See also
http://www.scribd.com/doc/18029452/NASA-SR71-Blackbird-Challenges-and-Lessons-Learned-2009
Thanks a lot for the excellent collection of data.
I took another look at the set of pictures on Wikipedia that shows the engine/spike at different Mach values and when you look very closely you can see that at Mach 3.2 with the spike retracted 26 inches, the shockwave is just barely attached at the front lip of the nacelle. Which makes sense in order to have subsonic air entering the inlet.
What doesn't make sense is why the spike is extended at all the lower Machs instead of being slightly more retracted and still trying to have the shockwave just touching the lip of the nacelle. I would think that having the spike too extended is also a bit bad in that having the shockwave way in front of the nacelle would allow enough distance for the air to develop some eddies and probably drag before being ingested by the engine. But I'm probably thinking too localized and not knowing enough about the bigger picture, ie the shock waves being thrown off by the nose and canopy and what their interaction was with the shockwave at the engine spike.
Thanks
I believe the goal is to ensure that the shockwave off the spike doesn't coincide with the shockwave of the nacelle/intake.
I haven't seen the details of the shock off the nose to know how it affects the engines.Update (July 28, 2017): I found a video that nicely describes the SR-71 and J-58
Update (August 4, 2017):
Richard Graham - SR-71 J58 Engine Tour
This one stumped me also.
I think the spike is extended at lower speeds as the inlet needs to be bigger to take in more air as it is less compressed. (mostly for the turbofan engine anyhow).
The position of the spike also controls what percentage of the air is sent through the turbine, what percentage is routed around the turbine directly to the afterburner, and what percentage is dumped.
At full speed, 80% of the air bypasses the turbine.
Due to the constant never ending supply of "cool stuff" happening in Aerospace these days I'm creating this thread to consolidate posts every time something new comes along. Please feel free to add random information if its relevant. So to start things off here is the SpaceX Dragon launch coming up shortly, I'll be following up afterwards to see how it all goes. :smile: https://blogs.nasa.gov/spacex/
Thread 'SpaceX Starship development: 7th flight January 10'
Watch the progress live This is a fully stacked Starship (top) and Super Heavy (bottom). A couple of too-small-to-see cars near the bottom for scale, I also added a Saturn V and the Statue of Liberty for comparison. 120 meters tall, about 5000 tonnes when fully fueled. Twice the mass and over twice the thrust of Saturn V. The largest rocket ever built by mass, thrust, height, and payload capacity. N1 had the largest diameter.[/size] But its size is not the revolutionary part. It is designed...
Venus does not have a magnetosphere, so the Galactic Cosmic Rays (GCRs) environment shall be much worse than in a LEO environment. Looking to the std radiation models for Venus, the standard radiation-hard space level electronic component with tested immunity LET = 85 MeV-cm2/mg seems not enough, so, for example, a 1cm2 Si die will suffer considerable flux above this level during a long mission (10 years for example). So, the question is, usually we are not paying attention to latch-up...
