Why Does W(sub ab) = 0 and W(sub bc) = 4 in Dynamics?
  • Thread starter Thread starter giant016
    Dynamics Explain
The discussion centers on understanding the dynamics of a system involving two bars, where W(ab) = 0 indicates that the horizontal bar is stationary, while W(bc) = 4 suggests movement in the vertical bar. The user expresses confusion about how the block at point C can move along the x-axis without causing the horizontal bar to move, questioning the physical feasibility of the scenario. It is clarified that even if the horizontal bar is not moving at that instant, it can still have acceleration, leading to future motion. The pinned nature of point A ensures its velocity is zero, while point C has no y-axis velocity due to its confinement. The discussion emphasizes the importance of applying known values in equations for velocity and acceleration to solve for unknowns effectively.
giant016
My professor has given us the problem and solution here; http://mielsvr1.ecs.umass.edu/mie310/13-176.JPG however, he has left out steps. I want to figure out as much on my own as possible, but don't really understand this one.
One of the equations written is W (sub ab) = 0, W (sub bc) = 4. However, if the top bar (ab) isn't moving, but the verticle bar (bc) is moving, the block C would just spin in circles. It appears to be going in the X direction only, confined in a track.
Any help would be greatly appreciated, especially if you could just translate some equations into words. When I look at them I come up with things like the problem above where they don't seem physically possible or equal.
Thanks a bunch in advance.
The block is pulling on the vertical bar which pulls the horizontal bar. At that instant the horizontal bar is not moving, but it does not mean it doesn't have an acceleration. At the very next instant the bar will be moving.
Point A is pinned therefore stationary, meaning velocity=0 at A. The block at C is confined to the x-axis so a velocity component in the y axis=0 at C.
The first equation written there means the velocity at one point is equal to the velocity at a second point plus the velocity of the first point as seen from the second point.
Use what is known when you apply the equations for velocity and acceleration to solve for the unknowns
