Why don't I get shocks on neutral wire?
  • Thread starter Thread starter justwild
    Neutral Wire
The neutral wire in household wiring is designed to be at or near ground potential, which is why it typically does not deliver shocks like the live wire does. In AC systems, the neutral wire carries current back to the source, but it should ideally have minimal voltage difference from ground, often measured in millivolts to a few volts. The US National Electrical Code allows for a maximum of 3.6 volts between neutral and ground for 120-volt outlets and 6.6 volts for 240-volt outlets due to the nature of the circuits involved. The difference in voltage limits between 120-volt and 240-volt circuits is attributed to their phase relationships. In some countries, such as Australia and New Zealand, the neutral line is grounded at the household fuse or meter panel, enhancing safety and reducing stray voltage issues.
justwild
In my textbook the AC current is defined to be one which changes its direction periodically.
So according to the text both the wires of the AC supply should give you shock, but I felt the real shock when I observed that the neutral wiring didn't shook me!
So what is different in household wiring?
The neutral wire is called neutral because it is, well, neutral. The other one has AC, this gives AC between the two cables.
Link to diagram of household wiring (USA style):
hsehld.htm
At my home, depending on location, I measure up to 1/2 volt difference between "neutral" and "ground", due to issues like impedance. The US National Electrical Code translates into a max of 3.6 volts between neutral and ground for 120 volt outlet, and 6.6 volts for 240 volt outlet.
Going back to that diagram in hsehld.htm, at my area, that transformer has a single phase 6900 volt line and ground on the input side of the transformer, and a 240 volt transformer with grounded center tap (for 120 volt) output.
"Stray voltage" can be an issue for locations like dairy farms. Wiki article:
http://en.wikipedia.org/wiki/Stray_voltage
Why the higher limit between neutral and ground for a household 240v circuit than 120v? The 240v circuit is two 120v circuits on opposite phases, so shouldn't be able to pull anything further away from ground than a 120v circuit? Just wondering... I'm away from my copy of the code right now.
In Australia, New Zealand and maybe a few other countries
the neutral line is grounded at the household fuse/meter panel
Dave
I think it's easist first to watch a short vidio clip I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way? The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
