Why electric field between two plates ##\frac {σ} {ε_0}## ?
The electric field between two plates is given by the formula E = σ/ε₀, derived from Gauss' law. This relationship arises because the plates are treated as infinite sheets, where the distance between them is negligible compared to their size. The electric field produced by an infinite sheet is uniform and does not vary with distance from the sheet. When considering two parallel plates, the fields add up, resulting in the factor of two in the final equation. Understanding this concept typically requires knowledge of Gauss' law, which will be covered in upcoming lessons.
Arman777
Insights Author
Why electric field between two plates ##\frac {σ} {ε_0}## ? Where is that came from ?
Gauss' law.
cnh1995 said:
Gauss' law.
ohh we didnt learn it.But we will..I guess I should wait then
I didnt understans...I will ask in class
There is another way of getting the result, by integrating vectorially the field created by each differential element of area of each plate.
cnh1995 said:
Gauss' law.
In a recent thread you said you're using (or will be using) Giancoli's book. Gauss's Law is in chapter 22 and capacitors are in chapter 24, according to the table of contents which are listed here. (click on the Table of Contents link).
Yeah we will learn gauss law in couple weeks
When using two plates, they are normally placed very close to each other. The distance of separation is extremely small compared to the size of the plates. This is essentially the concept of an "infinite sheet." An infinite sheet is an infinitely large, charged sheet. Technically, the electric field due to an infinite sheet is: http://tinypic.com/r/hss6jn/9 http://imageshack.com/a/img924/8000/MPvupe.png (application of Coulomb's law). R is the measure of a dimension of the sheet, and its proportional to the area of the sheet. x is the distance from the sheet to a point. Since the sheet is infinitely large, R is infinitely large and is therefore much greater than x, so 1/ (√(r^2 / x^2) +1) becomes extremely small, to the point where it no longer has an impact on the magnitude of the electric field. Since x does not have an effect on the magnitude of the electric field, the electric field has the same magnitude at every point. The electric field then becomes: E = σ/(2ε_o). The electric field between two plates is twice the magnitude, and that's where your equation comes from.
