Why gyroboards are said to run so long on one battery charge....
  • Thread starter Thread starter Yuri B.
    Battery Charge
Gyroboards advertised to run for two hours at 20 km/h with a 48V 4.4AH battery and 700W motor raise skepticism due to basic physics, as the motor's power draw suggests a much shorter runtime. Many users argue that advertisements often present ideal scenarios, such as coasting downhill, rather than realistic performance. Actual range estimates vary, with some claiming around 10 to 13 miles on level ground, which seems optimistic given the power requirements. Discussions highlight concerns over battery quality and safety, with past incidents of fires affecting consumer trust. Ultimately, while marketing may exaggerate capabilities, understanding the actual performance and limitations is crucial for potential buyers.
Yuri B.
Hello
Ads say a gyroboard with the battery 48V 4.4AH, and the motor 700 Wt will run for 2 hours at the speed of 20km/h ! But - simple physics - will not the motor drawing about 10-15 Amp exhaust the battery in just some 20 minutes !? Do ads lie ?
Yes, ads lie or at least they take the best scenario possible like coasting downhill for two hours if that possible with a gyroboard with a very light weight person riding it.
I tend to use the range as a better limiting factor as I wouldn't want to get stranded and have to carry the board back home but that's just me. I think the range for these is about 13 mi or about 20km on level ground.
http://www.toptenthebest.com/beauty-sport/top-10-best-hoverboards/
Some reviews say 10mi per charge and 7mph maximum speed.
My scooter powered by 24V 7AH battery, the (brushed) motor 250 W runs 4 mi. I have added more 7AH batteries (so 14AH now), so am having now 8 mi range.
But how on Earth anything powered 48V 4.4AH, the (even brushles) motor 700W could run 10 mi (let alone 13mi) ?
According to the article from Hoverbly, http://hoverbly.com/best-hoverboards-for-sale-ultimate-buyers-guide the Powerboard is able to drive with a top speed of 10 km/h, and your battery can last for up to six hours. I don't know if that's true but it seems to me that driving 6 hours at that speed might require pretty strong battery.
That sounds like a liberal estimate. Not sure how much power it takes to run at 10 km/hr, but from my experience with model aircraft power consumption can be quite high when demanding performance. What do those scooters have like 200 Watt-hours. I doubt it takes any less than 50W to propel that board at any appreciable speed, probably more. Even with that conservative estimate of power required that's only four hours run time. They were putting poor quality batteries in those scooters so the Watt-hour rating was greatly optimistic anyway.
There were incidents of battery fires due to those poor quality packs which gave the scooters a bad rep. I don't see them advertised at all anymore and I don't think anyone is buying them now. It's funny, I happened to see HSN advertising a sale on them and they kept emphasizing the brand was "improved" with safety features to eliminate the fire hazard. They probably still didn't sell any.
Yuri B. said:
Hello
This sounds about right.
From my research, a hoverboard should consume about 80 watts at a speed of 20 km/hr.
The 700 watts is the maximum power rating.
Yes, it is simple physics. Unfortunately, you did your physics wrong.
It would if there were not a speed limiter. At 700 watts, I calculate your top speed at around 46 km/hr.
Aerodynamic power consumed varies by the cube of the speed. Rolling resistance varies linearly.
My equation, based on wikipedia's bicycle power at speed graph is: watts = 0.0066*(kph^3) + 1.384*kph
Do ads lie ?
I concur with the following:
jedishrfu said:
Yes, ads lie
But, bad physics lies more, IMHO.
ps. The Swagtron T1 hoverboard stats seem about right:
watt hours: 155
rated speed: 12.9 km/hr
rated time: 2.5 hours
my interpolation of a 100% efficient system:
rated time: 4.9 hours
jedishrfu said:
ads lie
It is not necessarily lying (it all depends on what the definition of is is. I mean lying is.). It implies (but definitely does not promise) that you can go the fastest speed for the longest run time. If you listen to the exact wording you will find some weasel words caveating the crap out of the statements.
Read the fine print. Its still probably lying-ish but you get what you pay for.
BoB
PS: OK. I'm playing devils advocate. It is lying in the nicest possible manner.
it's not always about speed but battery life is also something that matters a lot because if you are continuosly charging you hoverborad at every 6 miles (coz you are a speed freak and will spend most of your battery in it)..then it's of no use...i am not discouraging you from buying as hoverboard if you really want to buy a hoverboard then you can get one for yourself from http://www.2kreviews.com/best-hoverboards/
