Why higher resistance means more heat produced in a circuit
The discussion centers on the relationship between resistance and heat production in electrical circuits, specifically regarding nichrome as a heating element. Nichrome 80/20, known for its high resistance, is favored for heating applications due to its ability to convert electrical energy into heat through Joule heating. The key equations discussed include P = I²R and P = V²/R, highlighting that while increasing resistance can reduce current, the power output remains significant when connected to a constant voltage source. The consensus is that higher resistance in heating elements leads to greater power dissipation when voltage is fixed.
  • Understanding of Joule heating principles
  • Familiarity with Ohm's Law (V = IR)
  • Knowledge of electrical power equations (P = I²R and P = V²/R)
  • Basic concepts of electrical resistance and material properties
  • Research the properties and applications of Nichrome 80/20 in heating elements
  • Explore the implications of Joule heating in circuit design
  • Learn about the impact of wire gauge and length on resistance and heat production
  • Investigate the design considerations for electrical appliances using heating elements
Electrical engineers, appliance designers, and anyone involved in the development or optimization of heating elements in electrical devices.
sgstudent
They say that nichrome is a better heating element as it has a higher resistance. But if I take V=RI then ain't I decrease since R is high, so current is lesser. Thus, resulting in a lower power dissipated as heat?
Also, they aq if I use the wrong wires like thin wires, it will cause a lot of heat produced as thin wires has a lot of resistance. Using the same reasoning I don't get why higher resistance results in greater power...
If current is constant then greater resistance results in greater power but I thought that voltage is usually constant? So when R increases, I will decrease and cause low power?
Thanks for the help!
sgstudent said:
They say...
Who are "they"? They're wrong.
Nichrome is a good heating element.
From Wikipedia :
"A heating element converts electricity into heat through the process of Joule heating. Electric current through the element encounters resistance, resulting in heating of the element.
Most heating elements use Nichrome 80/20 (80% nickel, 20% chromium) wire, ribbon, or strip. Nichrome 80/20 is an ideal material, because it has relatively high resistance and forms an adherent layer of chromium oxide when it is heated for the first time."
If you want to design a washing machine, or a water cooker, you know in advance what power the heating element should produce, and so you know the resistance it should have.
You can then use a short thick wire made of nichrome, or a longer or thinner wire made of some other material with a lower resistivity.
If you make the wire thinner, it will also become hotter, because the same amount of heat has to flow through the smaller surface area of the wire.
If you make the wire longer, it won't fit.
So you have to make the wire both thinner and longer, and it will have to be rolled up somehow inside the heating element, if you don't want to make the heating element itself larger.
Electrical isolation will be a pain, since plastic, rubber etc. won't stand the heat, and you probably need a ceramic around the wires.
You're forgetting the resistance of the power source and transmission lines. If the heating coil were made of a similar length of similar gauge copper, it would draw huge amounts of current, but most of the voltage would be dropped across wiring rather than the heating element.
P = I^{2}R
So as resistance increases, power does too...
OJFord said:
P = I^{2}R
This is not the equation you use, when you design an appliance with a heating element in it.
You know that the voltage across the resistance will be equal to the mains voltage, and that the the power must be whatever is needed to drive your hair dryer, toaster or whatever.
The resistance is thus fixed by P = V^2/R, and the only question is what material, length and width to use to make such a resistance. See my earlier post.
Apologies, I didn't really read the question fully.
But regardless, if you do not assume that you are working in this manner, the equation P=I^2R holds true for heating elements, surely?!
Ie, I'm testing some different elements of varying resistance, and recording the power output when driven from the same source. P will be greater for elements of greater resistance - that's all I was saying.
Both equations are valid when talking about power, but the point here is that we are connecting our heating element to a voltage source. So the the voltage across the circuit is going to remain the same as long as the current draw is within reason. That's why you work from V^2/R. Now if you use I^2R, the problem is that the current is going to change due to the equivalent resistance of your circuit. So while you may increase the resistance, you will also see a decrease in the current from the same voltage source.
Shut the switch off, which is essentially introducing infinity ohms into the circiut. See how hot it gets then when the current drops to 0.
  • · Replies 38 ·
  • · Replies 57 ·
13K
