Why in MOSFETs Halo doping is done near source and drain junction only?
Halo doping in MOSFETs is primarily implemented near the source and drain junctions to address the challenges posed by short channel effects, particularly punch-through, which occurs when the space charge regions of the source and drain come too close. This localized doping helps to suppress the width of these regions, enhancing device performance. Additionally, halo doping is also applied beneath the inversion channel to maintain a minimal impact on the threshold voltage. The strategic placement of halo doping is crucial for optimizing the electrical characteristics of the MOSFET as channel lengths decrease. Overall, this targeted approach is essential for improving the functionality of modern MOSFETs.
amitrt
Somewhere I read that the reason of halo doping in the MOSFETs is to increase the average doping of channel as the channel length is scaled to lower values. But I think there should be more about why is it done only at the source drain junction, and not somewhere else randomly like at the center.
Awaiting for your thoughtful reply.
In the short channel MOSFET, there is a possibility for the space charge regions (SCR) associated with the source and the drain to come into close proximity/contact with each other. This gives rise to the so-called effect of punch through. By performing the halo implant, you suppress the width of the SCRs.
Note that the halo is not only near the source/drain but it is also underneath the inversion channel. By doing this (as opposed to doing it "randomly like at the center"), the affect on threshold is minimal.
Hi,
thank you for the very informative and wonderful reply.
amit
I think it's easist first to watch a short vidio clip I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way? The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
I don't need cloth simulation. I need to simulate clothing meshes. Made of triangles and I need an answer that someone with High School math can understand. I am actually using the time it takes for someone to answer to create a model with less geometry than the one I have been using. I want clothing that can be removed on a model that will be animated. I don't need stretching or wrinkles on my meshes, I just need gravity. I have an idea of how I could do it, but I don't know how to apply...
