Is Faraday's Law Always Zero?
  • Thread starter Thread starter latentcorpse
    Faraday's law Law
Faraday's Law states that the line integral of the electric field around a closed loop is equal to the negative rate of change of the magnetic flux through the loop. While the electric field can be expressed as a gradient of a scalar potential in electrostatics, this only holds when there are no moving charges. In dynamic situations, where charges are in motion, the electric field also includes contributions from changing magnetic fields, making it non-curl-free. Therefore, the right-hand side of Faraday's Law is not zero in these cases, as it accounts for the time-varying magnetic fields. Understanding the distinction between electrostatics and electrodynamics is crucial for applying Faraday's Law correctly.
latentcorpse
ok so Faraday's Law says that
\oint_C \vec{E} \cdot \vec{dr} = -\frac{\partial}{\partial t} \int_S \vec{B} \cdot \vec{dA}
but we know that \vec{E}=-\nabla \varphi
and so \oint_C \vec{E} \cdot \vec{dr} =-\oint_C \nabla \times \nabla \varphi \cdot \vec{dA}=0 by Stokes' Theorem.
therefore, why isn't the RHS of Farady's Law just 0 all the time?
Haha, I had this exact same question the first time I took E&M
The electric field is only curl free in electro statics, when there are NO moving charges. When there ARE moving charges the electric field is no longer curl free, and obeys Faraday's law.
In the terms you presented, in electro statics the E field is due to a gradient of a scalar potential; however, in electro-dynamics, where charges can move, the E field is due to a gradient of a scalar as well as the time derivative of the vector potential. Thus, the closed line integral of E is no longer required to be 0.
In deeper terms, the electric field is not just due to static charges, but also due to changing magnetic fields. This is exactly what Faraday's law is trying to say.
i thought it might be that. what do you mean by curl free?
Curl free means that the curl of the field is zero.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
