gladius999
- 60
i think its to do with huygens sources?
gladius999 said:i think its to do with huygens sources?
Edgardo said:When a plane wave is incident on the slit Huygen's principle says that new waves are created in the slit. You can now calculate the interference pattern behind the slit by adding up all the little waves that are created in the slit.
This is done by writing down an integral (see \psi_{\mathrm{rad}}(\theta,\phi,r) here).
You can approximate the integral and end up with a Fourier transformation (see here).
For a more thorough discussion read Eugene Hecht's optics book. Also look up Fraunhofer diffraction.
It is nice to see a little calculi here in the formula as well. Is the slit an axiom, logically yes.dulrich said:I'm not sure this really answers your real question, but the conservation of momentum looks like:
\sum \vec{p}(0) = \sum \vec{p}(t)
In this case, all the momentum is in the x-direction, so \sum p_y = 0 both before and after. Since the y component is zero, any contribution in the positive direction (i.e., up) must be compensated by a contribution in the negative direction (i.e., down).
