Why is temperature & pressure constrained in a saturation state?
In a saturation state, temperature and pressure are interdependent, meaning that a specific temperature corresponds to a specific pressure for saturated water and steam. However, volume and internal energy vary between saturated water and steam, even at the same temperature and pressure. Thermodynamic equilibrium requires that there be no internal work or heat transfer, which is only possible when both phases are at the same temperature and pressure. This relationship highlights that while temperature and pressure define the state of a substance, other properties like volume and internal energy differ based on phase. Understanding these dynamics is crucial for analyzing thermodynamic systems.
swampwiz
Given the 4 main properties - Temperature, Pressure, Volume & Internal Energy (with the others derived from these), is is such that in a saturation state, temperature & pressure are constrained, such that, e.g., saturated water & steam (and any quality in between) at a particular temperature corresponds to a particular pressure - and vice versa. However, the volume & internal energy (and all the other properties) are different for saturated water & steam (and for any quality in between.) It seems that there must be a reason for this.
Perhaps the reason is that for material to be in thermodynamic equilibrium, there cannot be internal work done or heat transferred. And as work is only done if there is pressure difference - and heat transferred is there is a temperature difference - for a saturation state to be in equilibrium, the material in the 2 phases must be at the same temperature & pressure,
There probably is a better explanation, but I think I have the gist of it here.
Science news on Phys.org
Two properties are needed to define the state of the substance - all other properties then fall into place.
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
