Why is the Center of My Microscope Image Lacking Contrast?
The discussion centers on a microscopy issue where the center of the image lacks contrast compared to the periphery, despite using an Olympus BX60M microscope. The user has adjusted the field and aperture stops, achieving some improvement but still experiencing significant contrast differences. The problem persists visually and in smartphone-captured images, suggesting potential saturation or vignetting effects. Participants suggest checking alignment and using different objectives to diagnose the issue further. The conversation highlights the need for proper adjustments and understanding of microscope settings to achieve optimal image quality.
remorris44
https://www.dropbox.com/sc/eo2c8j4kd12pdvn/AACGJ8YZvk35BSX1BsBoKIIsa
Please view the above image. I am getting awesome contrast on the periphery of the image but hardly any in the center. The sample is an H and E stained tissue and I just got the microscope in today.
I am a rookie with microscopes so any ideas as to how to get this nice contrast across the image? Adjusting the brightness doesn't change much.
What microscope are you using?
It is an olympus BX60M. Got it for free from the university surplus department.
When I adjust the field stop/aperture stop just right I can see the good contrast around the center but otherwise the entire field of view is at comparable resolution but very poor contrast.
I'm sorry, I'm not actually too familiar with microscopes. Are you saying that if you adjust the stops just right it fixes the problem and you no longer have a contrast issue?
No worries, just glad to have someone to bounce ideas with.
No, the problem is with nearly every setting. Only when the stops are just right can I get a glimpse of the good contrast.
I want to say that it is a vignetting type of refraction artifact but if so it's pretty sad to say that an artifact region provides the best image...
Is the center bright spot just a contrast issue, or is the camera being saturated? You said adjusting the brightness doesn't help, but is that the brightness of the illuminating lamp, or just the brightness setting of the camera?
The photo was taken via smartphone so it did pretty much get saturated in the center. The effect is less dramatic in the microscope when looking with the naked eye but still drastic (contrast difference between stained tissue and nothing). With a dimmer setting on the scope the color contrast is still dramatically different. I want the colors to 'pop' like they do on the periphery of the posted photograph.
Okay, so the contrast issue is a problem both visually and photographically. Honestly I'm not sure what to do. If I find something that may help you I'll let you know. Hopefully someone else here on PF has more experience in this area and can help you.
Does it happen with other objectives and/or eyepieces? (i.e. did you get any other objectives or eyepieces?)
Assuming you have aligned everything correctly (http://www.well.ox.ac.uk/_asset/file/zeiss-guide-to-microscopy-from-the-very-begiining.pdf is a fantastic place to start), that looks like field curvature- the center may be in focus, but as you move towards the edge of the field of view, the image becomes defocused. What objective lens did you use?
