darth boozer
- Messages
- 90
- Reaction score
- 46
I found an even worse wiring situation in an old pub in South East London, UK, where my friend, the landlady, had accidentally hit a light with a brush and broken the lamp socket. A fuse blew and I at first assumed the power was off. Being an electronics technician, I had learned to test things rather than assume and this may have saved my life, or at least a severe shock. Finding the lamp socket still live, I rechecked the fuses in the pub's cellar and found a blown fuse in a neutral line on a separate switchboard to the live fuses, which of course left the circuit live and unsafe to work on without extra safety measures. Removing both fuses, I replaced the lamp socket and then rewired and replaced the fuses.russ_watters said:I learned this while changing a lightbulb my dad wired in my parents' basement...
@HomeExperiement something perhaps less evident is consistency in the circuit itself - not just the devices plugged into it - is part of the safety equation. If you aren't paying attention to polarity, you may wire a circuit that works fine, but due to the switch being on the neutral side, it's always live even when switched off.
The ancient switchgear in the pub cellar reminded me that electrical practices in the the pre-WW2 era were different to the more modern (early 1980s) times and reinforced the concept of testing before attempting any sort of electrical work.
In the same pub, the landlord had replaced a broken plug on a pie warmer, but it wasn't warming so he asked me to check it. A slight tingling shock (I was insulated from ground) suggested that I should check the plug wiring. Sure enough, the landlord was red/green colour blind and had interchanged the live and Earth wires (the old colour scheme, red-live, black-neutral, green-earth).
