- 2,801
- 606
In the wikipedia page for guiding center,the following lines are written about curvature drift of charged particles.
My problem is the part that tells curl of B is zero in a vacuum.
Although I know Maxwell equations permit such a situation(with \vec{B}=\vec{B}(\mbox{only space variables}) \ and \ \vec{E}=0),I don't understand how that can happen.
Obviously a current has caused the existence of the magnetic field and so there should be a changing electric field.But there is no electric field and that seems strange to me.
I'll appreciate any ideas.
Thanks
The expression for the grad-B drift above can be rewritten for the case when \nabla B is due to the curvature. This is most easily done by realizing that in a vacuum, Ampere's Law is \nabla\times\vec{B} = 0. In cylindrical coordinates chosen such that the azimuthal direction is parallel to the magnetic field and the radial direction is parallel to the gradient of the field, this becomes
<br /> \nabla\times\vec{B} = \frac{1}{r} \frac{\partial}{\partial r} \left( r B_\theta \right) \hat{z} = 0 <br />
Sincer B_\thetais a constant, this implies that
<br /> \nabla B = - B \frac{\vec{R}_c}{R_c^2} <br />
and the grad-B drift velocity can be written
<br /> \vec{v}_{\nabla B} = -\frac{\epsilon_\perp}{q} \frac{\vec{B}\times \vec{R}_c}{R_c^2 B^2} <br />
Thanks
