Why is the electric field intensity zero at only one point?
In summary, the EFI is zero only at (-4,0) because of the way electric field strength is calculated. Drawing the electric field lines may not fully explain this, as the E-field is a vector field with both magnitude and direction. A computer may be needed to accurately represent this concept.
imranq
57
Suppose you have a Cartesian coordinate system with:
a 2uC charge at (0,0) and a -8uC charge at (4,0), why is there only one point in which the EFI is zero (-4,0)? Shouldn't that be the first point where the EFI is zero (so (-5,0),(-6,0)... all have Electric Fields of zero)
The reason I think this is because if you drew the Electric field lines from one charge to the other, they wouldn't go either way infinitely.
Thanks
Electric field strength is zero only at (-4,0) because field strength are given by (up to a multiplicative constant)
[tex]\displaymath{\frac{q}{r^2}}[/tex]
so at (-4,0)
you have
[tex]\displaymath{\frac{2}{4^2}+\frac{-8}{(4+4)^2}=
\frac{2}{16}-\frac{8}{64}=0}[/tex]
whereas at (-5,0) you get
[tex]\displaymath{\frac{2}{5^2}+\frac{-8}{(5+4)^2}=
\frac{2}{25}-\frac{8}{81} \neq 0}[/tex]
I know that, but can you explain the field itself, since drawing the electric field lines doesn't seem to explain this
it is very hard to draw field lines to explain this, you will need a computer to help to do this properly. mind you an E-field is a vector field and at each spacetime point it has a magnitude and direction, so strictly speaking, to draw this properly you need to insert at each point a little vector, do this for each charge separately and you will find that only at (-4,0) will the magnitude be the same AND direction is opposite (ie cancel after doing the vector sum)
1. Why is the electric field intensity zero at only one point?
The electric field intensity is zero at only one point because at this point, the magnitude of the electric field due to all charges is equal in all directions, resulting in a net electric field of zero.
2. How does the electric field intensity being zero at only one point affect the surrounding charges?
The electric field intensity being zero at only one point affects the surrounding charges by causing them to experience no net force. This can result in the charges remaining in equilibrium or moving along a path of constant potential.
3. Can the electric field intensity be zero at more than one point?
Yes, the electric field intensity can be zero at more than one point. This occurs when the electric field due to multiple charges cancels out at multiple points, resulting in no net electric field in those regions.
4. What is the significance of the electric field intensity being zero at only one point?
The significance of the electric field intensity being zero at only one point is that it represents a point of equilibrium where the electric field due to all charges is balanced. This can be useful in understanding the behavior of charges in an electric field.
5. How does the location of the zero electric field point relate to the distribution of charges?
The location of the zero electric field point is dependent on the distribution of charges. It will be closer to the charges with larger magnitudes and farther away from the charges with smaller magnitudes. The exact location can be determined using Coulomb's law and the principle of superposition.
