Why is the expectation value of an observable what it is (the formula)
gothloli
I really do not understand why the expectation value of an observable such as position is
<x> = \int\Psi*(x)\Psi
If Q is an operator then
<Q> = = \int\Psi*(Q)\Psi
cn = <f,\Psi&gt;
What I understand this is saying is that since x is a linear transformation and \Psi is an eigenvector, by x\Psi would be a vector in position space. Then taking the expectation value is like taking the inner product of \Psi, and a position eigenfunction. But why would that give an average value? What I vaguely understand is that \int\Psi^{2}, is the probability density and multiplying operator by probability would give the average value. But I'm still confused as connecting linear algebra with probability and quantum, I'm having a hard time with that.
It is like a weighted average, where the weight appears via the wave function in the integral.
It just works this way. Why? Ask nature.
It's important to understand this. It's the key of the probabilistic meaning of the quantum mechanical state. An observable is represented by a self-adjoint operator in Hilbert space, and there's a complete set of (generalized) eigenfunctions u_j(x) of this operator. The (generatlized) eigen values (or better "spectral values") of the operator are the possible values the observable can take, and the probability to measure the jth eigenvalue, given the system is prepared in a state described by the normalized wave function \psi, is given by
P_j=\left |\int \mathrm{d}^3 x u_j^*(x) \psi(x) \right|^2.
The expectation value is then given by
\langle O \rangle = \sum_j o_j P_j.
Using the completeness of the (generalized) wave functions you can then easily show that you can write this expectation value in the way given in your question.
Likes 1 person
Ok, I understand, that makes sense.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
