Mentor
- 50,926
- 26,969
SamRoss said:if one twin stays on Earth while the other flies off in a rocket and comes back, I can't use those physical distinctions as a general rule to decide which one will be older when they meet? Sometimes it will be the Earth twin and sometimes it will be the rocket twin?
Since the Earth is a gravitating body, spacetime in this scenario is not flat, so you can't apply flat spacetime rules to it. Did you intend to have the Earth there? Or were you really intending to ignore gravity altogether and assume flat spacetime?
To answer the question as you ask it, with the Earth and gravity included, consider two possibilities:
(1) The rocket twin launches upward from Earth at less than escape velocity (we'll pretend there are no other gravitating bodies present anywhere, for simplicity) and then just let's his rocket coast until it reaches maximum height and falls back to Earth, landing at the same spot it took off from. The Earth twin is in a shielded bunker next to the launch point the whole time.
(2) The rocket twin launches upward from Earth at the same velocity as in #1 above, but uses his rocket to turn around long before it would reach maximum height if it were just coasting.
In #1 above, the rocket twin will have aged more. In #2, it depends on the details of when the turnaround happens.
