bobie said:
Of course we know this flight is technically impossible, but just to explore what would happen:
If time is, say, 1/10 of the time outside the ships should get 1/10 of the regular acceleration
I cannot attach any meaning to this statement. Please try to be specific, using accepted definitions.
bobie said:
When the radio waves are picked up inside the ship they they get in at a shorter wave but the words jam ten times quicker, but they cannot understand English any more because their brain is 10 times slower, right?
If a ship is orbiting (a supermassive BH; even for a neutron star, there is no orbit that is .9c) at .9c, radio waves sent from a far away ship would be received blueshifted by the orbiting ship. There is one factor affecting wavelength (shorter than at source), frequency (greater than at source), interval between signals (smaller than at source). It is not clear if you are suggesting these affects add up - they do not, they all correlate with the same factor. However, for people inside the orbiting ship (talking, turning on lights, etc.) everything is indistinguishable from if they were floating far away from any massive body. It is only signals received from far away that are received differently (as described above) from the way they emitted. Note, that if such a signal were slowed down by the given factor, then the English would be perfectly comprehensible.
Note, also, that we cannot talk about signals received from the BH, because that is impossible.
bobie said:
They cross the moon 10 times in a second ( their second) so, as the know the the orbit is 2π c, they are moving at 10 c in their frame?
Near a BH, geometry is non-euclidean, the ratio of circumference to radius is no longer 2 pi, and distance to a BH is challenging to define in a way that can be measured.
I suggest you accept my accelerating scenario and stick to SR rather than GR. There I already explained that the ship would consider the Earth (not the other way around as you keep saying) to be moving faster than c and this is no more surprising for such a non-inertial coordinates than a merry go round observer seeing distant mountains moving faster than c.
[edit: The question of how the ship would measure the speed of the moon, assuming the ship accelerating in a circle near the moon's orbit, passing it periodically, is actually quite complicated. If you measure the moon's passing locally, as it passes you, it will be .9c. This is accounted for by distance contraction. However, to model the moon's average speed over an orbit from the rocket point of view, you need a complete coordinate system. This is actually quite complicated for such a circular accelerating rocket, but it doesn't really matter what the result might be - there is no expectation that motion of bodies must be less than c in highly non-inertial coordinates. What is true, is that the moon would never overtake any light signal in any direction, in any coordinates. This is because in non-inertial coordinates, light may move many times faster than c]
bobie said:
Thanks for your kind patience, Dalespam
