Why is the motion of a piston considered to be simple harmonic motion?
The motion of a piston is considered simple harmonic motion (SHM) because it can exhibit oscillatory behavior similar to that of a pendulum, particularly under ideal conditions. The mass of the piston and connecting rod does influence the system, primarily affecting the time period of the motion rather than disqualifying it from being SHM. In an idealized scenario with negligible damping forces, the piston can oscillate back and forth in a manner consistent with SHM. The discussion highlights that while pistons can have various motions, they can still demonstrate SHM characteristics under specific conditions. Understanding these principles is essential for analyzing piston dynamics in mechanical systems.
SonicBoomxxx
I know this is simple, but I don't fully understand why the motion of a piston is considered to be simple harmonic? Wouldn't the piston and connecting rod have mass?
With an infinitely long connecting rod, you would have comparable acceleration and velocity values for the piston and crank pin.
A piston can have any motion you want. Are you talking about some very specific application of a piston?
Simple harmonic motion is for small vibrations in an isolated system(free from damping forces). If you have a pendulum of mass 20g it can also undergo shm. Mass just affects it's time period. A piston can also undergo shm.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
