Why is work done expressed as F.dx instead of x.dF?
105 replies · 15K views
Dale said:
Well, that sounds like a reasonable heuristic, but mathematically neither F nor dx has any restrictions related to time
I meant that x.dF is not physically possible at all as we can only get a finite displacement from an infinitesimal force if we apply it for an infinite time. So maybe this is also a plausible argument for x.dF not having anything to do with work.
AlphaLearner said:
Prove me then differential or integral of a function like f(x) = 2x will give a zero.
Yes, of course the Indefinite Integral (the inverse of the derivative) may not be zero but the Definite integral would be appropriate when calculating Work Done. That involves subtracting the indefinite integral,, evaluated for one value of F from the Integral, evaluated for another value of F. When the two values of F are the same, the definite integral will be zero.
Perhaps you need to find out what definite integrals are all about. If you are working from a calculus textbook than you need to look for the chapter on definite integrals or you may find this link useful. You will need to follow it all through.
Thank you Dale and sophiecentaur for making me understand definite Integrals, I kept indefinite Integrals in mind and asked it .You did not understand post #48 because you thought F.dx was work done for entire process, I thought that F.dx is just a piece of total part F.X! And that's why we find a need to integrate F.dx to get total work done in the process, at least between two points.
Here is a graphical representation of ##F=x^2## (black line):
The blue area represents the integral:
$$\int_4^8 Fdx$$
The orange area represents the integral:
$$\int_{16}^{64} xdF$$
This should help you visualize how different can be ##Fdx## and ##xdF##.
Why nobody uses ##xdF##? Because ##x## is a position that is dependent on how you define the frame of reference, so it is rather useless. But the difference between two positions (##dx##) is the same no matter what is the frame of reference.
For example, say you want to know the distance between 2 points (imagine 2 cities on a map). One point has the position (0) and the other one (10). The distance is is 10 - 0 = 10. But if we change the system of reference where the origin is somewhere else, the first point may hold the position (32) and the other one (42). The distance is still 10 (= 42 - 32).
In such a case evaluating something based on the position would be meaningless as it would change depending on your frame of reference.
But there are cases where you can have meaning for both integrals. In thermodynamics, on a Pressure-Volume diagram, you can evaluate ##Vdp## or ##pdV## to evaluate the work done. The ##pdV## form is called boundary work and relates to a closed system, like when a fluid is enclosed within a chamber that can vary in volume (piston-cylinder arrangement), but the mass inside stay constant. The ##Vdp## form is called isentropic shaft work and relates to open systems where fluid comes in and out like with a turbine. In that case the physical volume of the turbine doesn't change, but the output pressure is different from the input pressure. ##Vdp## considers the ##pdV## part, but also the work needed to maintain the flow within the system.
(Again, replying to this to get your attention)Please can you reply to post #48? (Sorry, I mistakenly said #49 last time)
Work is defined as the integral of F.dx. Since x.dF is not equal to F.dx it is proven that it is not equal to work. You don't need a plausible argument, you have a definite mathematical proof.
Post #48:
Mr real said:
F.dx is meaningful as it is possible to get dx displacement by applying force for an infinitesimal time but it would require infinite time to produce a displacement x from dF force, which is not possible.
2 things are wrong.
First, time has nothing to do with this. Nobody assumes that the displacement is the consequence of the force. If a force is moving (i.e. there is a displacement) then, by definition, there is work.
Second, x is not a displacement, it is a position. dx is a displacement, i.e. the difference between 2 positions.
Can this be looked at by considering the idea of duality ?
A physical problem can be formulated as a basic mathematical model or as the dual of the basic mathematical model .
Integral F. dx has meaning in the basic model and integral x.dF has meaning in the dual ?
Do you have a reference which discusses x.dF and its physical meaning in the dual model you are talking about?
I'll just say why I had the doubt about this in the first place, maybe answers to this will help in clearing up my confusion.
Okay, so when i first read that small work done is F.dx , I was able to see it as if we apply a force F for a small displacement dx then it would give the work done for this displacement (small work done) and then if we keep on applying force F (which can be constant or variable) for x displacement, then we would get the work for x displacement (total work done). Then I thought isn't this possible too that if we apply a very small force dF for displacement x, this would also be small work done and then if we continue applying force till it reaches the value F, we would get the total work done as F.x (this x would be different from the x for dF force)
Mr real said:
Then I thought isn't this possible too that if we apply a very small force dF for displacement x...
x is not a displacement. dx is a displacement.
'dx' is too small. 'x' says a significant value of displacement. I feel Mr Real gets closer but the second part of his explanation in #70 saying 'dF' force causing displacement 'x' is not a valid case.
No, x is a specific value of the position. ## \Delta x ## is a finite displacement . And dx is an infinitesimal displacement. xdF will be the value of position times the change in force, while at this position. There is no displacement involved in this expression. If there is a change in force is not due to a change in position. This expression may be nonzero maybe only for a time-variable force.
So does x being a position instead of displacement makes x.dF not meaningful?
I don't know if it is not meaningful, but it is not work for sure. Like someone already said, it defines a force that varies while staying at the same position. By definition, to have work, you need a displacement.
Can you provide a reference that says that x is not displacement in this case, its just position? Because if it's true then it gives the answer to this discussion.
Mr real said:
Can you give a reference that says that x is not displacement in this case, its just position?
Even I need some kind of proof, how 'x' is position.
In coordinate geometry, 'x' is called position/coordinate only if it has displaced from origin and that magnitude is what displacement means.
Simply to say 'x' is magnitude of length between two points.
You clearly want to find out about this and to get it 'right' in your head. In that case, you should use a better disciplined source for your information than a thread that starts as this one did. Nothing was defined and it was assumed that we all knew what the OP meant; we clearly didn't. The resulting chat has probably confused you more than you needed.
This hyper physics link puts the calculation in a well behaved way and for a force that varies with displacement. That is how work is defined. No other definition can be relied on to give the right answer for a general case. Frankly, I don't see any point in investigating other combinations of symbols on the off chance that it will deliver the same answer as the accepted method.
A good textbook is worth its weight in gold and it is a shame that people don't rely on them. Even when money is a problem, there are on line sources that will do the same job better than you can ever rely on a pleasant chat amongst people with a range of levels of knowledge. :smile:
Sophiecentaur, if you are online, can you please reply to post #48?
Thank you for the link, but I had already gone through that and that I have another question now ( thanks to that link). How is work a line/path integral? Because I had read that a path integral depends on the path followed but work doesn't?
And now I know that x.dF cannot be the work done. But my question isn't that, now it is: What am I doing wrong when I see x.dF as applying very small force dF for a finite displacement x?
Thanks for reference, It was all as I studied. Wasn't able to put my thoughts clearly. No coverings/excuses, Seriously.
I have learned the concept of work on my own referring my textbooks, made no less use of them. Nobody taught me. Even this is the first time seeing a question like this and made my try onto it putting my thoughts so even I get better understanding.
I realized that people are not getting what I mean to say. I quitted from this discussion regarding it after Dale's warning and once again learning integration so I see where I am going wrong in expressing.
It is the usual way of defining ##x## in a cartesian coordinate system. In the case of a one-dimension system, the distance between 2 points - i.e. a displacement - is ##\sqrt{\left(x_2 - x_1\right)^2}## or simply ##x_2 - x_1##.
But it could be defined as you said, i.e. a distance from some reference origin. Although, if that was true, it would only work with a straight path (unless ##x## would be defined as the path traveled from the origin) and if you wanted to compare ##xdF## with ##Fdx##, then what would be the meaning of ##dx##? A small displacement beginning at the origin? It wouldn't make sense.
But can you provide a reference that explicitly says that in this case, i.e. in the case we are considering (work ); by x we mean a fixed position(or coordinate)?
The same symbol may be used in many areas to mean different things.
Now, dx is a part of x and both are displacements, only x is finite but dx is infinitesimal in magnitude. Even in integration that's what we do, if we integrate all dx terms, we get x; now if dx is displacement then it's integral would also be displacement, it cannot be any other quantity. Also, we know work, W= F.x , here x is displacement by the definition of work, as it is said to occur only when a force produces a displacement , (therefore we take into account the displacement, not the position); for example, if a body was at position x=2 and after applying a force F it reached x=7 m position; we wouldn't take 7 in our formula, we would take x=5(7-2), so x is displacement.☺
Regards
Mr R
The general mathematical definition of work is:
$$W = \int_a^b \vec{F}(r) \cdot d\vec{r}$$
This is known as a line integral of a vector field. From Wikipedia:
Applications
The line integral has many uses in physics. For example, the work done on a particle traveling on a curve C inside a force field represented as a vector field F is the line integral of F on C.
So it does represent the work done.
where · is the dot product and r: [a, b] → C is a bijective parametrization of the curve C such that r(a) and r(b) give the endpoints of C.
What is parametrization? Again, from Wikipedia:
Parametric equations are commonly used to express the coordinates of the points that make up a geometric object such as a curve or surface, in which case the equations are collectively called a parametric representation or parameterization (alternatively spelled as parametrization) of the object. For example, the equations
627bb5a6d2b57174bd596f1fc7990592b8e6076b
form a parametric representation of the unit circle, where t is the parameter.
So it should be clear that ##\vec{r}## is an expression of the coordinates of the path.
If ##\vec{F}(r)## is always parallel to ##d\vec{r}## then you can simplify to:
$$W = \int_a^b F(r)dr$$
If ##F(r)## is constant, you can further simplify to:
$$W = \int_a^b Fdr$$
And if the path from ##a## to ##b## is along a single dimension (say ##x##), then you simplify to:
$$W = F(x_b - x_a) = F\Delta x$$
Which is the simplest form found in physics textbooks.
Here is a representation of ##x## and ##dx## (shown as ##r## and ##dr##):
##dr## is the displacement along the path, which is what we care about. It is a distance. This is the same vector no matter where is the origin of the reference frame.
##r## is the vector between the origin and the vector ##dr##. It is also a distance. This vector depends on where is the origin.
If ##dr## begins at the origin, then ##r = 0##.
So when we say ##\Delta x = x_2 - x_1##, we actually simplify the vector equation ##\vec{\Delta x} = \vec{x_2} - \vec{x_1}## which looks like ##\vec{dr} = \vec{(r+dr)} - \vec{r}## in the previous figure.
Regards
Mr R
Why are you wasting time with this. The simple derivation of work down with force F over a distance x is Fx. We know that. When the Force is not constant, the work has to be calculated using a Definite Integral between limits x1 and x2 of F(X)dx. Any other way of arranging those symbols has nothing to do with Words as we define it. There is nothing more to me said about the matter but the thread is 86 posts long. How can this be?
I agree. Enough already.
Enough. Even I have got enough from this and x.dF will not give a value we want just like how k is taken as 1 in F = k.ma through observation when we solve F α Δmv/Δt similarly, x.dF would have not given actual values when observed practically.
I'm done with this.
