Why Multiply Carbon Isotope Mass Numbers by 1.67x10^-27 kg?
  • Thread starter Thread starter kashmirekat
    Atomic Estimate
The discussion centers on the need to multiply carbon isotope mass numbers (12, 13, 14) by 1.67x10^-27 kg to estimate their atomic masses for a mass spectrometry problem. It is clarified that while atomic mass units (amu) are commonly used, the conversion to kilograms is necessary for calculations involving electric and magnetic fields. The user confirms that since the equation requires mass in kilograms, they should use the conversion factor provided. The importance of understanding the relationship between mass, charge, and the resulting motion of ions in a mass spectrometer is emphasized. Ultimately, the conversion to kilograms is essential for accurate calculations in this context.
kashmirekat
Here's a verbatim section of the problem:
" The source contains carbon isotopes of mass numbers 12, 13, 14 from a long-dead piece of a tree. (To estimate atomic masses, multiply by 1.67x10^-27kg). "
My question is isn't the 12, 13, & 14 in the atomic mass units already (Carbon-12 has an amu of 12)? Why would I need to multiply? And if I do need to multiply, should I leave it in kg or convert to g?
Thank you.
I'm afraid you haven't given enough of the problem statement for us to know what exactly you are going to be doing with the carbon masses so that we can know if you really need to convert to some unit such as kg. Since whoever wrote the question took the effort to provide a conversion factor for you, it is pretty likely that you really do need to make use of the conversion factor.
To an approximation, an atomic mass unit is kinda sort of the mass of a neutron or the mass of a proton. This glosses over the fact that the proton's mass is a little different than the neutron's mass. Also, there are issues of binding energy when protons and neutrons bind together to form a nucleus.
Way back when I was a kid, I am pretty sure they liked to call either the mass of a certain isotope of oxygen a perfect 16.00000 amu, or else maybe it was that the mass of the carbon-12 isotope was taken to be a perfect 12.00000 amu, I can't remember which.
I was afraid that would not be enough info, the entire question is as follows:
Suppose the e field between the e plates in the mass spec is 2.48x10^4 v/m and the magnetic fields B=B'=0.68T. The source contains carbon isotopes of mass #s 12, 13, 14 from a dead tree. (estimate masses by x by 1.67x10^-27) How far apart are the lines formed by the singly charged ions of each type on the photographic film?
I thought I would need to multiply since they bothered mentioning it. However, I do not know if I should convert to grams or leave it in kg. The eq I used is r=(mE)/(qBB')
Thanks
Nevermind, Telsa is in kg so for it to cancel I have to use kg.
Thanks.
Ah yes.
One Tesla is one kilogram[/color] per second squared per ampere.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
