Why must brake pads and rotors wear out?
  • Thread starter Thread starter FreeForAll
    Brake
The discussion revolves around the reasons why brake pads and rotors wear out in passenger vehicles, exploring both the scientific principles behind wear and alternative braking methods that could potentially eliminate the need for replacement. Participants consider various braking technologies, including traditional friction brakes, eddy current brakes, and regenerative braking systems.
  • Some participants question whether it is possible to slow down a vehicle without causing wear, suggesting that current methods inherently involve physical contact that leads to wear.
  • Others propose alternative braking technologies, such as eddy current brakes, which do not wear out in the conventional sense, but note their limited application.
  • Magnetic fluid turbos are mentioned as another potential method for braking, though details on their effectiveness are not fully explored.
  • Regenerative braking is discussed as an ideal solution, with considerations about the limitations of energy storage systems like batteries, which can wear out and have capacity issues.
  • Participants express uncertainty about whether wear is an unavoidable consequence of kinetic friction or if it could be mitigated through different methods, such as vibrating particles instead of physical contact.
  • One participant highlights the effectiveness of current systems in dissipating heat and the safety benefits of traditional braking methods, suggesting that hybrid systems combining regenerative braking with conventional brakes may be optimal.
Participants generally agree that wear is a significant issue with current braking systems, but there is no consensus on whether it is an unavoidable consequence of braking or if alternative methods could eliminate it. Multiple competing views on braking technologies and their effectiveness remain unresolved.
Limitations include the dependence on specific braking technologies and their applications, as well as unresolved questions about the mechanics of wear and the effectiveness of alternative braking methods under different conditions.
FreeForAll
I understand their job is to convert motion into heat, but can it not be done without causing wear on a regular passenger vehicle? Even if price is of no concern?
Is it just we didn't find/create the ideal materials yet, or is there a scientific reason why they MUST wear out eventually? Bonus question: If we ignore brake pads and rotors (and cost), what would be the ideal method of slowing down a passenger vehicle without the need to replace brake components for the life of the vehicle? Is an electric motor the best solution we have today?
Have you heard of eddy current brakes? https://en.wikipedia.org/wiki/Eddy_current_brake
They are different, and they would not wear out in the conventional sense.
But for various reasons, they are not used in many applications, so I must conclude that they are not best for those applications.
How about magnetic fluid turbos on each wheel?
If you brake by having moving surfaces in physical contact with each other, you're going to get wear.
You can avoid wear by using breaking methods that do not make physical contact, as others have exemplified.
Yes Ideally some form of regenerative braking. Put the energy back in the "tank".
However there are complicated issues... Such as what if the tank is a battery which just happens to be too full or too hot/cold to take any more energy?
And of course, batteries wear out.
Is this only in the context of my example (slowing down a vehicle), or is this a general rule that any time 2 surfaces rub each other to generate heat there must be wear?
I understand how shearing off microscopic particles generates heat, I was just wondering if the same heat could be generated by having the particles vibrating, but not actually breaking off.
I'm sure if it were that simple it would be in use now, I just don't know if it's a technical reason we haven't surmounted yet, or if it's a "law" that says there must be wear.
I took these answers and did a bit of research - seems like electricity is the way to go. I found out an electrical system (eddy current or electric motor) becomes less effective as the road speed drops. So if you're crawling in traffic they may not be effective. I guess this could be resolved by adding energy to the system (such as trying to turn the motor backwards). It might not make economical sense to do that, but I guess it does answer my original question. Being able to use the energy generated is a big bonus.
Magnetic fluid seems like it has no problem working at slow or even zero speeds, however I don't know what happens to this fluid as it heats up or how to make use of the energy.
Ye, my understanding (though I am having trouble finding a specific reference) is that kinetic friction and wear are two parts of the same thing. You can't have one without the other.
One nice thing about the system as it exists right now is that the majority of the heat gets dumped into the rotor, which has a very high temperature capability and is directly exposed to the air, making it very good at shedding heat. In addition, as a braking system is a key safety system for the vehicle, the simplicity is a large benefit (a backdriven electrical motor has substantially more failure modes than a hydraulic cylinder pushing pads onto a disk). Because of that, I'm inclined to say the best system for a lot of cars today is how hybrids and electrical cars do it - have regenerative braking for normal use, but still have disk brakes for emergency or maximum effort stops. Many modern hybrids and electric cars can go well over 100k miles on one set of brake pads, and over a quarter million on one set of rotors, so they've very nearly made them lifetime components already.
13K
  • · Replies 43 ·
16K
  • · Replies 71 ·
13K
  • · Replies 17 ·
19K
  • · Replies 69 ·
18K
  • · Replies 46 ·
13K
  • · Replies 19 ·
10K
