Why operation * not defined in Q
  • Thread starter Thread starter pakkanen
pakkanen
Show that l/m * k/n = (l+k)/(m2+n2) can not be defined as an operation in Q when l,k € Z and m, n € Z\{0}
I do not know what is the issue here? Should I know something about Q that this not fulfilled by the operation *?
Hint: What happens if you negate l and m?
Ok.. So the same operation can produce two different results??
So that l/m * k/n = (l+k)/(m2+n2) ≠ (-l+k)/((-m)2+n2) = -l/-m * k/n = l/m * k/n
That's right, so the operation is not well defined.
Thank you very much jbunniii! Helped me a lot. I think we'll meet again.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
