Why Do TV Cables Use 75 Ohm Impedance?
  • Thread starter Thread starter freydawg56
    Cables Ohms
TV cables use 75 ohm impedance primarily due to a balance between loss and flexibility, as thicker wires at around 50 ohms would be less practical. The minimum loss for coaxial cables is approximately 77 ohms, influenced by factors such as dielectric type and propagation velocity. Calculations indicate that 77 ohms yields the lowest attenuation for specific coaxial designs. Additionally, the skin effect losses on the center conductor increase at other impedances. The choice of 75 ohms also aligns closely with the impedance of a dipole antenna, which is about 73 ohms.
freydawg56
we learned it could be a trade off between loss and flexibility. Because if it was around 50 ohms or so it would be too thick of a wire.
and the we learned the minimum loss is around about 77 ohms.
What do you guys think.
Many years ago I recall calculating the optimum impedance and found ~77 ohms to be lowest attenuation for a fixed coax OD and dielectric type (solid, foam, etc.). The minimum attenuation impedance may depend on the propagation velocity (i.e., dielectric type). As I recall, at other impedances the skin effect losses on the center conductor were higher. Foam polyethylene dielectric is better than solid. See
http://www.dxzone.com/cgi-bin/dir/jump2.cgi?ID=14693
Bob S
The real reason is that 75 ohms is closer to the real part of the impedance of a dipole at around 73 ohms.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
