Why use inverter and not correct ac source to ac drive directly?
Using an inverter with an AC drive allows for variable speed control of AC motors, which is not possible with a direct AC source connection. Directly connecting an AC source through a transformer does not provide the flexibility or efficiency that converters offer. Converters enable the adjustment of voltage and frequency, optimizing motor performance and energy consumption. This approach can lead to better system reliability and reduced wear on equipment. Overall, utilizing converters is a more effective solution for controlling AC drives.
Eatmealive
Hi all, I have a question with regards to why should we use an ac-dc, dc -dc, dc-ac converter to an ac drive? Why not connect an ac source through a transformer directly to the ac drive? Isn't it the same? What equations can prove that the use of converter is a better choice?
Welcome to PF!
Are you talking about a variable frequency drive? They are used so you can vary the speed of an AC motor. Otherwise they are typically connected "across the line'.
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
